LQ4 in a 1971 Nova
Old Aug 4, 2011 | 07:36 PM
  #161
crosstraining's Avatar
Those seats look nice!
I'll be keeping a close eye on this A/c upgrade. That is the next thing for me, if I ever get my car drivable.
Old Aug 4, 2011 | 09:24 PM
  #162
tsnow678's Avatar
X2 on what crosstraining said!!! Nice!!! I am about to pull the trigger on the same A/C unit. DSE sells a bracket that is supposed to make installing the evap unit alot easier. Have you heard about this any???
http://www.detroitspeed.com/1967-196...mgnm-brkt.html
Old Aug 4, 2011 | 10:17 PM
  #163
74novacustom's Avatar
Come check out where i put my AC compressor, im using the factory truck ac compressor and bracket. id like to see the ac unit as well, that will be my next purchase.
Old Aug 4, 2011 | 10:22 PM
  #164
-TheBandit-'s Avatar
Cool in more than one sense of the word! Look forward to seeing what you come up with. AC in AZ must be virtually mandatory this time of year.
The seats look great too. I put some Nissan seats in my Nova that also sit too high.
Old Aug 5, 2011 | 04:01 AM
  #165
tsnow678's Avatar
Do you have a link to your build?
Old Aug 5, 2011 | 10:07 AM
  #166
hookemdevils22's Avatar
Tony, I heard about that bracket at Steve's Nova Site. The evap is a serious pain (did a VA system on my GTO last summer), so I say if you've got the coin to do it.
I'm also thinking of putting down some Dynamat-esque stuff. Any reason not to use the Fat Mat rattletrap stuff on eBay?
EDIT: 74nova is in PHX, so he meant to check out his car in person. the fact that it's an AWD build was intriguing enough in & of itself, but the sound deadener and AC bracket are further reason to check it out.
Old Aug 5, 2011 | 10:17 AM
  #167
https://ls1tech.com/forums/conversio...going-awd.html
Also about the sound deadening, I own a little company that sells sound deadening mat, though i nolonger keep much in stock, its just a side gig, come check out the deadening in my ride, its quieter than my escalade. Fatmat will work depending on how thick it is and its core materials.
Old Aug 30, 2011 | 04:21 PM
  #168
What year Tarus is that fan from? It does seem to be a great fit for the factory radiator.
 Michael S. Palmer
Old Aug 30, 2011 | 04:30 PM
  #169
It's from a mid-90s 3.8L Taurus. The fan is a 2-speed... I initially ran it on low, but my 350 ran a little warm (though cooler than the flex fan that was on it before), so I swapped to high speed when I did the LSx swap. I also bought a Mark VIII fan (which flows more), but it was too deep.
Here's a pic. The underside of the shroud (below the fan in the pic) has an odd cutout that I epoxied a cover over. Note that there's another, less desirable, Taurus fan that has a taller motor and straight blades. You don't want that one.
These are plentiful in the JY... I saw a guy pull about 15 of these one day while I was out looking for a fan seupt for my GTO.
PS - The VA system is supposedly on the way. I'll likely begin tearing it down next week to do the install. Stay tuned for further updates...
Old Aug 30, 2011 | 07:37 PM
  #170
billsnogo's Avatar
Watching again!
I would love to add air to my car IF I get it driving again. Hope it goes well for you
Old Sep 14, 2011 | 10:52 AM
  #171
got a nice birthday present last night... though it took a bit longer than I was hoping. at least it's cooled off enough so I can work on the car more (and won't be needing AC for a few months, haha). I'm doing some work to my Jeep this week (and still in the process of moving/cleaning up the new place) but hope to start the AC swap this weekend. I'll also be putting in some sound deadening material (thank you Richard) and designing my own compressor bracket.
Old Sep 14, 2011 | 12:03 PM
  #172
Your Welcome. Looks like some new toys lol. Have fun and post plenty of pics.
Old Oct 23, 2011 | 11:51 AM
  #173
And it's in! The VA kit took all of two weeks to install, so the bulk of time was figuring out the AC bracket. The cool thing is that this bracket should work with truck accessories running car intakes as well as those retaining the truck intake, and you have the option of running an idler pulley if you want a different belt routing. In fact, I had all but the belt figured out last weekend, but I was in Alabama for business all week. I finally got it finished yesterday (all but two spacers, at least, but I used a couple others as temps), and we took her out to a show in Mesa last night. The heat works awesome, and I'm charging the AC this morning. Anyway, onto the pictures:
My 'Warren Bros' bracket retains the 'car intake with truck accessories' belt routing.
Plenty of clearance between the belt and the TB/water pump pulley.
Condenser fit perfectly, especially with no hood latch.
Accumulator/dryer tucked in the passenger fender.
The hoses are also routed inside the passenger fender...
...and they enter the cabin through the kick panel.
The kick panel was the biggest pain of the install, as the VA instructions are incorrect. There's no way it fits per the instructions, nor do the screw holes align.
VA kit retains the OEM controls, but gets rid of the cables.
Ducting tucked in well.
The driver's side vent (far left) was relocated to the right of the steering wheel due to my OBD port being on the other side.
Clean install, for the most part. The evaporator tucks away nicely behind the vents (it is installed in this pic).
Evaporator as installed. I didn't check when drilling the drain hole, and put it over the passenger side header. I had to rotate the outlet slightly and add a small length of hose to ensure it doesn't drip over the header.
Old Oct 23, 2011 | 05:12 PM
  #174
tsnow678's Avatar
Great job on the VA system. You will love it! I am soooo glad I have heat and air now. It just adds to the modern convenience of these cars. I can leave my windows closed now and listen to the radio. No more carrying a towel around wiping off the inside of the windshield.
Old Oct 24, 2011 | 11:49 AM
  #175
It's wonderful. I had to remove the heater core when I did the LS swap, so it's nice to have heat, and even better to have AC!
Old Oct 24, 2011 | 12:57 PM
  #176
Nice work! That belt routing is exactly what I was talking about. It's great you can eliminate that upper idler that Kwik normally uses. It just doesn't seem necessary with the truck-style belt routing. I'm trying to come up with a way to do that kind of routing with my FEAD because I really like how the truck-routing zig-zags & fully wraps both the crank and the waterpump.
I love how the gen IV integrates with the factory controls. It looks really clean. Great work.
Old Oct 24, 2011 | 01:01 PM
  #177
Lookin Good, how does it work?
Old Oct 24, 2011 | 02:17 PM
  #178
it works wonderfully. the AC was at 40° and the heat at 120° out of the vents when we charged it. I will say this - I am a little concerned that the belt kisses the water pump pulley during transient operation at higher rpm's with the AC on. I'm going to monitor and maybe switch to another style belt routing.
Old Nov 14, 2011 | 05:09 PM
  #179
small update... I switched the belt routing due to the rubbing issue. It now has less contact around the crank, but doesn't rub anywhere like it did with the previous routing. Unfortunately, it appears that rotating inertia of the AC compressor would slacken the belt between it and the idler pulley during rpm drops with the AC on. It would then droop and contact the portion of the belt riding on the water pump pulley. While it was a quick touch-and-go, it was still enough to warrant new routing. On the bright side, I eliminated the idler just below the alternator. Had I run the truck intake I would've been able to do without 'my' idler altogether.
Look ma, no idler!
Old Nov 14, 2011 | 06:16 PM
  #180
tsnow678's Avatar
Belt routing looks just fine! Congrats on getting the A/C complete. I see you opted for the polished compressor. Looks good.
