Need input: carb size on LQ4
I have a 6.0L, +0.030, looking to do a carb swap.
Eventually I will want to add a small shot of juice to it. It will be an auto car, and I am researching heads (L92, AFR, etc.) at the moment.
But what size carb are you running, or what size is too big? I have read alot of articles with guys running LARGE carbs, on engine dynos. So I need opinions from those who are running these engines in their cars.
Putting it in a 2nd gen Camaro. The car will be streetable, but will definitely be hitting the track!
Im only running about 74 primary jets, 76 secondary jets, a 6.5pv, a 30cc accelerator pump, a #33 squirter with the hollow screw and a stretched white spring for the vacuum secondarys.
SHAWN- have you sprayed the motor yet?
I could run a 650 on my setup if i wanted to but i chose a 750. I'm moving to an 850 demon because i wanted the mechanical secondaries and i just got a good deal on a particular 850 carb. I would have stuck with a 750 otherwise.
I have a double pumper with mechanical secondaries, I think model number 4779S. I am still fiddling with it, but the idle circuits don't seem to be a good match for the stock cam'd LS2 crate motor. I have the idle screws at about 1/2 turn and it is still a bit too rich at idle.
Any opinion on a used 750 mighty demon for 200 bones for this 5.3?
You probably wont even notice the different in driveabilty.
The problem with Demons is their quality control. If you see a used one cheap usually the person is getting rid of it because of problems. Out of the box they tend ot have metal shavings in the float bowls which isnt so bad as sometimes the metering blocks are drilled wrong (holes too big or not drilled at all) and ive heard some horror stories of them dumping fuel through the secondaries even while the engine is off.
I was honestly just thinking about picking up a plain jane 650 Holley DP to start off with for 75-100 bucks that needed to be rebuilt.
Picking up a carb that needs rebuilts is the BEST way in my opinion. This way you get to see all of the work parts of a carburetor and help you best decide which ones will work best with your set up. having the carb apart is the easiest way to learn them
Back to the origional post i would say 750 double pumper if the setup is under 3600lbs. If its over 3600lbs you might want to go with a vacuum secondary. It'll help you save a good bit of fuel.
I actually posted a timeslip for my N/A stock cu in combination using a Pro Systems carb.
Anyone else want to backup their "advice" with a timeslip?
You want an killer carb for your combo give Patrick James at ProSystems a call he will build you a carb for YOUR combo.
I have run off the shelf carbs from Demon and Holley and they work fine if dialed in properly and the right size/type for the motor.
There is no comparison between an off the shelf unit and one built specifically for you engine/drivetrain combination.
just my 2 cents........
Dave
Actually the Idle speed and A/F were adjusted dead on from Pro systems.
Shawn, you are actually making my point for me. The carbs you run require changes to work. The fuel curves that set up in off the shelf carbs are designed for a broad range of applications. Making jet changes and P/V changes are not what I am refering to when it comes to fuel curve.
Pro Systems carbs use a high emulsion sytem that provides a highly emulsified fog of fuel that the off the shelf casrbs can not compete with,(see ET in Sig).
The pump shot, jetting, P/V, Idle speed and A/F are set up out of the box for you combo.
When you buy a carb from them you are supplied a spec sheet with the setup parameters for your carb with lean rich adjustment ranges.
Additionally you get tech support from the owner free, I have called for recomendations for jetting changes for different atmospheric conditions and fuel specific gravity changes..... worth every penny!
I had always thought that an off the shelf design would perform as well as a custom... boy was I wrong.... worth at least 20-30 hp for about 80 bucks more than a new Holley... money well spent.
Do yourself a favor and go to the Pro Systems website and read the tech articles"under the scoop"
Dave
