l92 swap in 86gt mustang HELP MEASUREMENTS/ PICTURES NEEDED
i doing a motor plate for the ls1 motor
if anyone has a aje kmember with ls1 mounts
can i please get some measurements
from
back of the block to the firewall.
bottom of each cylinder to the frame rails (each side)
bottom of the block to the k member
PICTURES OF WHAT I DID TODAY
![](http://i40.photobucket.com/albums/e243/dkbykesdk/motor.jpg)
![](http://i40.photobucket.com/albums/e243/dkbykesdk/mustang-2.jpg)
PICTURE OF CAR stock radio everything still works, cars been 8.7s on motor!!
![](http://i40.photobucket.com/albums/e243/dkbykesdk/mustang-1.jpg)
![](http://i40.photobucket.com/albums/e243/dkbykesdk/nightmare2.jpg)
![](http://i40.photobucket.com/albums/e243/dkbykesdk/nightmare7.jpg)
from
![](http://i40.photobucket.com/albums/e243/dkbykesdk/nightmare5.jpg)
Keep in mind when I say k-member below, it means the tube running under the oil pan that the steering rack mounts on.
1)Rear edge of block(behind oil sending unit) is 1 1/2" from the face of the fire wall.
2) bottom of block(oil pan face) to top of k-member is 4"
3)F-body oil pan sump hangs down 1/2" below k-member.
4) the gap between oil pan sump to the read side of the k-member is 3/8"
5)the rear of the block ( bell housing surface ) to the rear of the k-member is 11 3/4".
![](http://img.photobucket.com/albums/v348/djquik88/swap%20picks/DSC_0539.jpg)
![](http://img.photobucket.com/albums/v348/djquik88/swap%20picks/DSC_0540.jpg)
![](http://img.photobucket.com/albums/v348/djquik88/swap%20picks/DSC_0541.jpg)
![](http://img.photobucket.com/albums/v348/djquik88/swap%20picks/DSC_0542.jpg)
![](http://img.photobucket.com/albums/v348/djquik88/swap%20picks/DSC_0543.jpg)
![](http://img.photobucket.com/albums/v348/djquik88/swap%20picks/DSC_0554.jpg)
![](http://img.photobucket.com/albums/v348/djquik88/swap%20picks/DSC_0561.jpg)
![](http://img.photobucket.com/albums/v348/djquik88/swap%20picks/DSC_0563.jpg)
![](http://img.photobucket.com/albums/v348/djquik88/swap%20picks/DSC_0567.jpg)
![](http://img.photobucket.com/albums/v348/djquik88/swap%20picks/DSC_0568.jpg)
![](http://img.photobucket.com/albums/v348/djquik88/swap%20picks/DSC_0569.jpg)
![](http://img.photobucket.com/albums/v348/djquik88/swap%20picks/DSC_0570.jpg)
