aje motor mount dimensions
PLEASE HELP!!! Can anyone shoot me the dimensions of an aje k member?
i need the length of the steel tubing that is welded to the carriage connecting the poly bushings for the motor mounts. the length of the tubing, and where it is welded to the k-member height and width.
I cut my k-member motor mounts so I can duplicate the aje mounting position
all help is greatly appreciated
I happen to have mine out of the car right now so it was easy to measure
this is for a 79-93 fox body.
looking at the k-member from the front....
rightside upper tube 5 1/2"
rightside distance from upper tube to point where a-arm attaches 5 3/4"
rightside tube from motor mount to lower tube 7 1/8"
rightside distance from the above tube to point where a-arm attaches 6 1/2"
leftside upper tube is 5"
leftside distance from upper tube to point where a-arm attaches 6 1/2"
leftside tube from moto mount to lower tube 6"
leftside distance from the above tube to where the a-arm attaches 3"
notice the measurements are not symetrical because ford mounts their engines offset to the passenger side.
