Ls1 Isuzu Pickup
Old May 29, 2009 | 05:46 AM
AussieALLMTR's Avatar
Default Ls1 Isuzu Pickup
Little project truck that me and a mate are working on. It's a 1990 model Holden Rodeo cab chassis utility. In the USA, these were called a Isuzu P'up.
http://img34.imageshack.us/my.php?image=10for101.jpg
We're trying to run 10 second 1/4's for a $10,000 outlay. So far:
$400 for the motorless truck
$1200 for the low milage 2005 Ls1
$50 for Th350 to suit rebuild
$50 for diff and tailshaft
$725 for Camaro rear sump setup
$50 for radiator and 3000cfm thermo fans
$40 for water pump
$56 for engine mounts
$24 for rear trans mount
$145 for Bosch 044 fuel pump with alloy bracket
$40 for rails and throttle body
Free injectors
$2780 total
The big expenses to come are the auto rebuild, an Ls1/Th350 stall convertor and the converted harness.
Hopefully the finished truck will be under 3000lbs.
Motor in position:
http://img43.imageshack.us/my.php?im...e250520092.jpg
Left mount/header done:
http://img132.imageshack.us/my.php?i...8052009001.jpg
Right mount/header done:
http://img132.imageshack.us/my.php?i...8052009002.jpg
After dummying the motor in the bay, we decided to cut a band out of the trans tunnel to get the motor further back. We also had to swap over to a Camaro sump setup for it's rear pan.
Motor and gearbox are now in and mounted. Modified some Holden Special Vehicles headers to fit. Over the weekend we hope to finish the trans tunnel and see whether we can use a modified factory tailshaft.
http://img38.imageshack.us/my.php?im...re24052009.jpg
We're also seeking an engineers advice re cutting 10 inches out of the chassis to shorten the wheelbase.
Old May 29, 2009 | 07:34 AM
TTLS1GP's Avatar
Isuzu Hombre....same as S-10
Good start. Keep it up!
Old May 30, 2009 | 10:49 AM
mgbrv8's Avatar
Will a 92 isuzu trooper manual trans bolt up to a ls1??
Dave
Old May 31, 2009 | 12:30 AM
12thstreetjunkman's Avatar
sweet build, I used to have a 90 pup with a 302 in it. They are def some of the nicer mini trucks. You really don't see to many of them around here.
Old May 31, 2009 | 06:29 AM
Thanx guys. Yeah they are quite common over here. Tomoro is a lot of running around picking up parts. Would REALLY have prefered a complete motor but the long one was too good a deal. Got to go into the city tomoro for the rails/coils/tb.
Hoping to get the diff conversion done this week and shorten the chassis (if the engineer agrees with that)
Old Jun 1, 2009 | 03:38 AM
Went and picked up some donated injectors last night
Engineer has given approval to shorten chassis as long as we run bracing plates inside it. Finished the tunnel today and hoping to get onto the diff/chassis tomoro. Also still running around for parts.
Gotta take the fuel tank down to a mate's workshop to get a surge tank welded to it. This is the fuel system as it stands now. By adding a 5 litre surge tank to the back, will bring capacity up to 25 litres which will be adequatish.
http://img136.imageshack.us/img136/8718/fuelsystem.jpg
Old Jun 1, 2009 | 07:13 AM
TTLS1GP's Avatar
Dave
What motor is it bolted to?
Old Jun 3, 2009 | 11:03 AM
Yesterday I went down to Sydney and picked up a throttle body and fuel rails. Also dropped off the fuel tank to have a surge tank/extension added to it.
Today the chassis got cut, plated and reattached minus 10 inches of rail. This brings the wheelbase back from 119 inches to 109 which should help with traction a bit.
http://img151.imageshack.us/i/shortened32.jpg/
You can see from the droopy handbrake cable how much has been removed.
So the motor is now in and mounted. The tunnel is done, welded and sealed. The extractors have been modified and are now fitted.
http://img151.imageshack.us/i/motorin53.jpg/
Tomorow the Borg Warner diff will be modified and fitted and the truck will be coming home for me to do the fiddly bits over the next month (or two)
Old Jun 3, 2009 | 11:39 AM
mgbrv8's Avatar
Its bolted too a 3.2 Isuzu v6.
Old Jun 4, 2009 | 10:17 AM
Diff conversion is done and truck is ready to come home
Pics up tomorow
Old Jun 5, 2009 | 04:12 AM
http://img14.imageshack.us/i/diffin1.jpg/
Looks crap but wire wheel and black paint will fix that
Old Jun 5, 2009 | 04:25 AM
ehnihl's Avatar
Good Luck...Keep us updated...
Old Jun 5, 2009 | 07:04 AM
TTLS1GP's Avatar
no. It needs to be the 90* GM variety...
Old Jun 5, 2009 | 07:12 AM
Shroomun's Avatar
Good luck..sounds like a good project
Old Jun 5, 2009 | 07:26 AM
GIGAPUNK's Avatar
What are you hoping for a race weight?
Old Jun 5, 2009 | 07:46 AM
Hoping for under 3000
Old Jun 5, 2009 | 07:33 PM
bad98t/a's Avatar
obviously, there arent alot of people doing swaps into "pups" but I have a buddy putting in a 4.3 and I was wondering what you did for motor mounts, or if you made your own used some stock configuration? Any advise helps, thanks.
Old Jun 6, 2009 | 02:36 AM
Nah mounts were full custom. Had to make brackets off the chassis forward of the crossmember and brackets off the motor. Used an aftermarket rubber as well. Most of the reason was that we made the mounts around the factory extractors so I don't know how this would pan out in a 4.3 setup
Old Jun 14, 2009 | 09:16 AM
Started dummying up the rear of the truck over this weekend. Trimmed off some brackets and cut another 8 inches off the back of the chassis. It's only getting a tiny little tray setup. Cut out a section to run the battery as far back as I can. Still got the auto cooler/fan setup to mount in there as well.
http://img193.imageshack.us/i/picture14062009001.jpg/
Old Jun 17, 2009 | 04:32 PM
wheelies247's Avatar
do you have any pictures of the motor mounts ??
i just bought a 90 isuzu pick short bed no cab but its a 4cyl and i got the car for real cheap and it in good shape.
did you have to cut out anything and how much ??
