Engine will not stay running at idle...
Old 10-17-2009, 07:23 PM
69chvl468's Avatar
Default Engine will not stay running at idle...
4L60E, GMP Hot cam, bbk intake and TB and the ecm was tuned for the cam. Its weird, it idled fine when it first fired. but now it doesnt fire unless I have the throttle open part way, and when I let off it dies... the MAL light isnt on, no trouble code either.
Old 10-17-2009, 07:27 PM
turbov6bryan's Avatar
Does it have a loose vacuum line? Any holes between the MAF and TB?
Old 10-17-2009, 07:37 PM
69chvl468's Avatar
No loose vacuum line. Only vacuum line is the brake booster, the rest are plugged. It might be the connection between the tb and maf. I have a bolt on style maf, sets in place with set screws. maybe thats the problem...
Old 10-17-2009, 10:13 PM
ssduane's Avatar
sounds like you need to do a idle relearn. Also try pulling the IAC out and making sure it is clean.
Old 10-18-2009, 10:09 AM
CalEditor's Avatar
What year setup is this and are you running a Cable or ETC?
Old 10-18-2009, 11:53 PM
69chvl468's Avatar
It's a 98 f body ls1 and ECM with a standalone harness and 4l60e. Running a bbk tb with a cable. It idled fine at initial start up, then disconnected the bat to do some work. Now it won't idle at all. And it only starts holding the throttle open while cranking. I'm still
green to the ls motors, so bear with me...
Old 10-19-2009, 12:11 AM
ls1nova71's Avatar
Take it out and drive it some. My car will do that when the battery goes dead when it sits over the winter, I have to keep it running. But after i drive it for awhile it goes back to normal.
Old 10-20-2009, 02:43 PM
69chvl468's Avatar
Ill try to get out and drive it, a little tough when it keeps dying at every stop sign!!!??
Old 10-20-2009, 09:25 PM
lamdenali's Avatar
The ECM need relearn, call your ecm guy to show you how to relearn the ECM, whenever you disconnect the BAT. it'll need to relearn
Old 10-20-2009, 09:54 PM
69chvl468's Avatar
Ok well I was able to take it out for a drive, drove it for awhile. It seems to be on and off like when ever it wants to stop idling. Sometimes it stalls, sometimes it doesn't. Waitformeperformance did my ecm. Ill try to give him a call..
Quick Reply: Engine will not stay running at idle...
