lsx fox need some advice.
1) I have no harness at all for the motor...SO i am open to ideas on what harness or what company makes a nice harness and what computer to use(I will be running the camaro gauge cluster). I have factory power windows and lock that i want to retain also, also would like to keep the turn signals and lighting working properly.
2) Im going to an automatic with this set up, Im torn between a th400 and a 4l60e. The motor will hopefully make about 400rwhp before spray (which will not be often used) i will be using an ls6 cam. The gears are 3.73, and i like to Drive my cars, not just the track. Thats why overdrive would be nice, but the th400 are virtually bullet proof.... What kind and brand stalls would you recomend.
Any input is appreciated.... Not sure what luck some of you have had, but thank you in advance.
I'm torn over the same trans swap question. Biggest thing I think is unless you go 4l60 you won't get converter lockup. I love to drive my car on the e way so that'd suck. I also do more street racing than track racing so I am not sure what to do. Same thing with the stall what size stall to run.
I've got an 88 and 94. I'm considering this swap myself on one of them as well. More than likely it'll be the 94 because the engine is out at the moment. Whats up with the gauge replacement? Is there any links that would go further to clarify what all is involved?
Is it actually possibly to make the F-body cluster look like it belongs in the Fox dash???
TIA.
Tipsy
