selling my lq4 motor and turbo setup out a 02 gt. Includes fuel system
Im selling my setup out of my 02 gt, should work in all mustangs i believe.
The motor its an 03 lq4 out a 2500hd with 45x miles on it. It has ARP rod bolts, Ls1 oil pan, Ls1 upper intake and throttle body. It also has 60 lb injectors EV6 pen style
The wireing is a custom made harness not a hack job and camaro ECU already programmed.
The turbo setup: its a Master power t70 if i rem correctly its 92mm intake 101mm exhaust, I have a 50mm synapse waste gate all piping (will fit 94 04 mustangs for sure may fit fox? It has a 4 core front mount air to air and the bov is a teil knock off.
Everything is there to put this in your car throw your tranny on it and crank it up.
I want 3000+ shipping or local pick up for the whole setup, The motor is still in the car I am located in Covington La if you would like to hear it run
i do have the A/c compressor and what not if wanted.
Price now includes the fuel system, Aeromotive a1000 fuel pump with filter,-10an braided hose. A1000 boost bypass regulator 60 lb injectors...
Im giving this away for 3k this is motor kit turbo kit and fuel system!
Pics
Pics please, I am really only interested in everything BUT the long block, If you dont want to seperate I understand and might be interested anyway. hineshouse@gmail.com
