My 67 camar0 LS1/4l60 swap thread
Old 01-06-2014, 09:59 AM
  #581
c6matt's Avatar
Trans is installed. It fit the tunnel better than the 4l70... Had to modify the crossmember mounts and trans cooler feed line. Shifter bolted right up. Trans harness had just enough length to reach the 4l80 plug. Lokar dipstick plugged right in. All things considered it was pretty painless. Aside from the driveshaft the only part left of the trans is to get a speed sensor plug and run it to the PCM for the input speed sensor.
20140103_103316.jpg?t=1389022851
Old 01-06-2014, 02:23 PM
  #582
tsnow678's Avatar
Tranny looks great! Hope it provides you years of service. Now its time to turn up the wick!
Old 01-06-2014, 11:08 PM
  #583
bmf5150's Avatar
I wish I went with a 4l80 originally,nice trans
Old 01-06-2014, 11:09 PM
  #584
bmf5150's Avatar
How big of stall u go with ?
Old 01-07-2014, 08:50 AM
  #585
c6matt's Avatar
thanks guys, pretty excited about it. The converter is supposed to be 2800-3000 stall. I make so much torque down low that it would be a waste to have any more, Chris at circle D said maggie cars love this converter, we will see. I now need to get a driveshaft, going to get an aluminum one good for 1000hp... 1350 joints too... no more DS failures for me, once was fun enough.
The wick is def going to be turned up (forged stroker is the plan).. but the new garage will be finished first.
Old 01-08-2014, 04:36 AM
  #586
bmf5150's Avatar
I'm going to upgrade to a lsx 427 and some 12degree cathedral port heads to match up with my kenne bell.. Are you going to step up to more cubes??408?418?
Old 01-08-2014, 06:53 AM
  #587
c6matt's Avatar
Wow, thats a bad azz combo.. I've been looking at the 408's alot lately.. I would relpace my "350" fender badges with 409..she would be really fine..
Old 01-08-2014, 10:07 PM
  #588
bmf5150's Avatar
Lol,yeah the 408 is nice !!!
Old 02-11-2014, 11:15 AM
  #589
c6matt's Avatar
Driveshaft fix arrived last week while I was up north cold testing
PST 3.5" .125 wall aluminum DOM Shaft with 1350 U joints and Strange Yolks, they recommend it for drag racing use up to 1000 horsepowerz!!!
20140120_152926.jpg?t=1390262574
20140120_153127.jpg?t=1390262596
The same model shaft is in this car...
Old 02-11-2014, 06:28 PM
  #590
tsnow678's Avatar
Awesome! Do you know if there is any weight savings between the two?
Old 02-12-2014, 12:18 AM
  #591
bmf5150's Avatar
Very nice!!!
Old 02-12-2014, 04:45 AM
  #592
cobalt964's Avatar
very nice car, I prefer the 67 to the 68-69's.
Old 02-12-2014, 06:49 AM
  #593
c6matt's Avatar
both shafts in the picture weigh about the same, but there is only half of the steel shaft left!
Old 02-12-2014, 06:53 AM
  #594
c6matt's Avatar
Thanks, an ls powered 993 GT2 is on my bucket list...sweet ride
Old 02-12-2014, 08:13 AM
  #595
Hart_Rod's Avatar
Great build Matt! Love the attention to detail. I've got a LS3/6L80/TVS1900 in my goldie also...
Attached Thumbnails My 67 camar0 LS1/4l60 swap thread-2011-12-1712_19_49.jpg   My 67 camar0 LS1/4l60 swap thread-20140208_164928_resized.jpg   My 67 camar0 LS1/4l60 swap thread-img_4701.jpg
Old 02-12-2014, 06:38 PM
  #596
c6matt's Avatar
Very nice... it looks like you have vette accessories, but not a standard looking magnuson for a vette...what is the application of that unit?
Old 02-12-2014, 07:46 PM
  #597
Hart_Rod's Avatar
Thanks Matt. The motor and tranny came from a 2013 Camaro SS. I mechanically deleted the VVT/AFM. The accessory brackets are from Holley (they mimic the Corvette on the drivers side). The Maggie came from a Denali, which has the same offset as the 2010+ Camaros. Everything went together pretty well. I had to build the support bracket for the snout, but it was fairly simple. I also used a Shriftersix paddle shifter setup, which integrated well with the 6L80 and VHX gauges.
Attached Thumbnails My 67 camar0 LS1/4l60 swap thread-img_4555.jpg
Old 03-18-2014, 10:01 AM
  #598
c6matt's Avatar
Finally got all the parts in the camaro and tranned the calibration into the new segment-swapped S/W for the PCM, the car now runs and can move (roads still too salty for a test drive) under its own power, no codes set with the 4l80 so hopfully it stays that way..
Old 03-22-2014, 08:37 AM
  #599
bonecrrusher's Avatar
Matt - when you getting started on your new garage?
Old 03-24-2014, 07:41 AM
  #600
c6matt's Avatar
Waiting on the snow to clear off the foundation, but it should be going by April 15th per my builder, hopefully I can get some of the insulation up and the big doors in by mid may.
What did your car end up putting down?
In the meantime, I now have a burnout switch..
Quick Reply: My 67 camar0 LS1/4l60 swap thread
