My 67 camar0 LS1/4l60 swap thread
Old 06-03-2016, 06:09 AM
  #661
c6matt's Avatar
Have an issue? I will say the 4l80 has been running like a champ. After ordering 9 months ago, my carbon body panels finally shipped.
Old 06-04-2016, 06:31 PM
  #662
Motown 454's Avatar
Looks sweet . Matt do you have any pictures of where the 4l80 trans harness connector is in the tunnel. I'm putting one in my 69 Camaro and its aweful tight. Beautiful car.
Old 06-04-2016, 07:48 PM
  #663
Jimbo1367's Avatar
c6matt,
do you think the LS dust shield would be the same as a a4 would use? I am in the need of in and only see it offered with the flexplate and bolt kit
Old 06-07-2016, 02:46 PM
  #664
ryeguy2006a's Avatar
Originally Posted by bmf5150
Beautiful Car!! Just read through the whole thread today. I am doing a 68 Camaro and putting in a 6.0 and 6 speed so this caught my eye.
I have to ask though, what are you doing for reverse lights? I am sure it is sacrilegious, but I am probably going with the 67 Tails on my 68 and I like the look without the RS reverse lights. But I have been wondering what to do with the reverse lights?
Old 06-08-2016, 10:15 AM
  #665
c6matt's Avatar
Just tapping the brakes while backing up with the LED panels I built is plenty of light. never had an issue.
Old 06-08-2016, 10:18 AM
  #666
c6matt's Avatar
c6matt,
Not sure what you mean. A LS 4l80 dust shield will fit any year 4l80. 4l60 parts will not work. Both are A4 transmissions.
The LS dust shields are a bit hard to come buy. If I see one in a junkyard I always grab it.
Old 06-08-2016, 10:20 AM
  #667
c6matt's Avatar
Originally Posted by Motown 454
Looks sweet . Matt do you have any pictures of where the 4l80 trans harness connetor is in the tunnel. I'm putting one in my 69 Camaro and its aweful tight. Beautiful car.
I do not as I am traveling for work. It is tight. I used a connector off of a 2500 4x4 truck that the wires exit at a 90* angle to the connector, and it just fit in.
Old 06-08-2016, 06:54 PM
  #668
Motown 454's Avatar
Thanks
Old 06-09-2016, 11:18 AM
  #669
Jimbo1367's Avatar
Sorry, you got my meaning though. LS/4l60
thanks,
Jim
Old 06-22-2016, 08:46 AM
  #670
c6matt's Avatar
thanks,
Jim
Yea, 4l60 has the one piece bell on the trans, no dust cover like the 4l80.
Old 09-27-2016, 11:43 AM
  #671
c6matt's Avatar
Saved ~ 100 lbs off the nose with some Anvil pieces. Took 9 monts to arrive, but worth the wait! (weight? LOL)
Attached Thumbnails My 67 camar0 LS1/4l60 swap thread-20160817_212748.jpg   My 67 camar0 LS1/4l60 swap thread-20160817_212754.jpg
Old 09-27-2016, 03:25 PM
  #672
Rocketrod's Avatar
Nice! Is that the 100% carbon fiber or carbon fiber/fiberglass mix? Does the understructure of the hood clear the supercharger?
What rearend and gear ratio are you running?
Old 09-28-2016, 11:25 AM
  #673
c6matt's Avatar
Yes, all carbon, and it needed a 4X9 section trimmed on the bottom.
3.73, wish it was a 3.42.
Old 12-02-2016, 03:07 AM
  #674
94 slow's Avatar
Great thread!
Do you know the distance between the firewall and the passenger/driver side heads? I'm building a 67 with an ls and 4l80, but I want the motor and trans as far back as possible.
Old 12-02-2016, 03:46 PM
  #675
Motown 454's Avatar
94 slow The further back you go the tighter the trans will be in the tunnel. I have about 1-3/4" from the back of the head to the firewall and the trans is pretty tight to get the right drive line angle. I'm just over 3-3.5 degrees down.
Old 12-02-2016, 05:40 PM
  #676
94 slow's Avatar
That's great info. I may cut/massage a little to get my desired location.
Old 12-03-2016, 11:20 AM
  #677
c6matt's Avatar
Agreed. about 1.5-2" max. If its apart put in a big block heater core and you will gain firewall clearance.
Old 12-14-2016, 05:40 PM
  #678
94 slow's Avatar
Guys,
thanks for the info. I'm not putting a heater core back.
Old 05-01-2017, 03:09 PM
  #679
94 slow's Avatar
Bringing this one back up...
Matt, did you notice a difference between the 1st gear in the 60 vs the 80? I'm hoping it's a non-issue with the supercharger
Old 05-02-2017, 07:19 AM
  #680
c6matt's Avatar
Better traction and a more usable 1st gear. With the light weight car and this much power I have too much to hook, throttle modulation is key. You'll never miss it. I am thinking about pulling my 3.73 and putting in 3.42...
Quick Reply: My 67 camar0 LS1/4l60 swap thread
