please take a look.Do you know what this is?
Old Jan 27, 2010 | 10:10 PM
fptransport's Avatar
Default please take a look.Do you know what this is?
anyone know what this is.. I am re doing my own harness into a stand alone,, I am about 97% done,, just need to know what this is... it has a harness that hooks to it, anyone? thanks in advanced ,. trying to post pics,, hopefully it will work
Old Jan 27, 2010 | 10:32 PM
ls1nova71's Avatar
Pics didn't work.
Old Jan 27, 2010 | 11:00 PM
here is the pics,,
Old Jan 27, 2010 | 11:04 PM
deuce4935's Avatar
Where r the pics?
Old Jan 27, 2010 | 11:16 PM
busta9876's Avatar
i'm going to take a guess...vortec 5.3 or similar harness??? Is it a 3 wire connector, black, near where the other two larger connectors were, a few inches down from the PCM???
Could be 4WD stuff, 4 low signal stuff....just guessing since no pics.
Old Jan 27, 2010 | 11:41 PM
I am trying to upload pic but it wont let me..I post pics before,, dont know whats going on... actually I had just sent you a email since I was able to upload there.. busta... the one of the plugs towards the rear I think it went to the fuel tank,,, its goes to pcm white wire and its a fuel temperature/compostion signal ? I guess I can eliminate that... the other I sent you the pic in the email. its a black connector and it has a loop hole that looks like a hose or a bundle of wires can go thru it... you ll see when you get the pic
Old Jan 28, 2010 | 08:22 PM
finally the pics
Attached Thumbnails please take a look.Do you know what this is?-dscf0142x.jpg   please take a look.Do you know what this is?-dscf0143x.jpg   please take a look.Do you know what this is?-dscf0144x.jpg
Old Jan 28, 2010 | 10:02 PM
pdsq98gt's Avatar
That is the generator battery control module. It is an ammeter that helps the charging system be more efficient.
Old Jan 28, 2010 | 10:49 PM
uphigh07's Avatar
exactly what he said ^^^^
Old Jan 29, 2010 | 10:33 AM
ls1nova71's Avatar
It has the negative battery cable run through it to measure amp draw.
Old Jan 29, 2010 | 02:35 PM
SUG's Avatar
SUG
this woudl be correct
Old Feb 21, 2010 | 06:29 AM
psiconversion's Avatar
LS1Tech Sponsor
Does anyone know if there is a way to bypass this module?
__________________
Your Source for LSX Conversion Parts!
www.psiconversion.com
Ebay Store
Facebook/psiconversion
Instagram/psiconversion
'Dont Let EFI Pass You By!'
