AFR LS2/69 Camaro
Been taking pics of my progress. Had a mild 355/turbo 350 before. Time for a change. So it will get an LS engine. However, not stock. So I found a new LS2/L76 for cheap and will use that as my base. I worked a long time getting the right specs on the cam to run and sound the way a true musclecar should. I will run a Victor Jr EFI intake with a 4 barrel TB on top with a chrome air cleaner. Coil packs will be hidden and clean Chevrolet valvecovers will be used to give that SBC look when first opening the hood. I also have a built 4L60e going in behind the LS2. Looking for ~550 fwhp/460rwhp when I'm done. Should be a fun streetcar. Enjoy.
I cut the intake relief .100"
Beings I didn't get a pullout from a vehicle, I'm piecing everything together. It's more painful and expensive this way
I will be in need of a harness and ecu shortly because I don't have either. This one will be faily unique because I have a DBC TB, 58x, 4x cam, Gen IV motor with knock sensors down low. I will use a lingenfelter converter box to get the signal to 24x and 1x because there is no ecu that reads 58x and DBC or so I'm told. What company should I use to build my harness? Where did you get this Spectra Tank? I just got off the phone with RockAuto.com and they said they don't list it and have no idea why they keep listing it online. He said that he noticed this same thing on 69 Camaro. Go figure.
thanks,
---Jim---
__________________
I'm sure many sponsors on the right are reputable. I've had several. Personally like my speartech harness-great craftsmanship, service after the sale, etc. $.02.
