L92/LS3 into 68 Camaro Newbie needs swap help!
Hey guys, I have some newbie questions. Never swapped anything before.
1. Is there a gasket for the tranny/motor connection?
2. Will the stock L92 fly wheel work with a 4L70E?
3. Will the tach sensor from the L92 PCM work with the stock 68 tic toc tach?
4. Does the original 68 trans cross member cut out or is it bolted in?
5. How/where did you run the new efi fuel tank wires?
6. Did you put the computers in the glove box or under the hood?
7. Where do you get a custom drive shaft from? or Retool what you have?
Thanks!!
Any help on any of these issue very much appreciated!
__________________
Thanks!!
__________________
1. Is there a gasket for the tranny/motor connection?no
2. Will the stock L92 fly wheel work with a 4L70E?yes, same as 4L60e
3. Will the tach sensor from the L92 PCM work with the stock 68 tic toc tach?no, different signal
4. Does the original 68 trans cross member cut out or is it bolted in?original crossmember needs to be modified or you can buy an aftermarket one
5. How/where did you run the new efi fuel tank wires? Inside, under rear seat, out to tank
6. Did you put the computers in the glove box or under the hood? underhood
7. Where do you get a custom drive shaft from? or Retool what you have?PST in Florida. http://www.pstds.com/contact_us.htm
1)No
2)Not sure, sorry
3)I believe you need some sort of dapter/interface of some sorts. Someone will chime in.
4)Bolted in.
5)you can run it down with the factory body harness/old sending unit wires and out to the new tank.
6)Your choice
7)Local driveshaft supplier or vendor to the right ~~~~~>
Be sure to take pics and share them here. This forum will answer just about any question you will encounter. Have fun !!!
2)Not sure, sorry
4)Bolted in.
6)Your choice
ya beat me. LOL. Which is good. You have more answered. LOL.
Thanks!
You guys are awesome.
here are photos.
http://www.flickr.com/photos/41575483@N07/?saved=1
Any further details on the tach would be awesome. I really want to keep all the stock gauges.
THANKS!!!!!!!!!
here are photos.
THANKS!!!!!!!!!
68Problemchild
I was looking at your pics and noticed you have your fuel line running across your intake manifold. IIRC.... you can flip your fuel rail 180* and clean up your eng. compartment.
On the fuel rail (and the rest of the car) I have not begun clean up yet. Still trying to get it running. Great idea on the fuel rail.
So you just pull it off and turn it around?
Andrew, on the shaft I do have 5-6" of splines in the tranny. Can I just get a longer yoke? Hate to pony up for another drive shaft.
Appreciate all the input.
on the fuel rail (and the rest of the car) i have not begun clean up yet. Still trying to get it running. Great idea on the fuel rail.
Andrew, on the shaft i do have 5-6" of splines in the tranny. Can i just get a longer yoke? Hate to pony up for another drive shaft.
If the length is off it can domino into other issues......= more doe...
68 Problem Child,
I was looking at your pics and I see the driver side PCV from the valve cover but I can't make out where you connected this at the intake end? Do you have any pics and or can you describe what you did?
BTW - Great looking car.
Pcv
I will have to get some more recent photos up. Thanks on the car.
My PCV goes from Drivers rear valve cover to pass side front of throttle body.
Passenger head cover goes to drivers side throttle body with a "T" for my air powered headlight doors.
I used to have a small air filter on the passenger valve cover (and the drivers side throttle body plugged) but was not sure if this was messing up my fuel trims with too much O2.
Most guys running this seem to have some type of oil catch can inline with tubes.
