oil sending unit
Old Apr 1, 2010 | 02:42 PM
bfrank79's Avatar
Default oil sending unit
where is the best place to tap into for the oil sending unit? I heard that you can tap it where the oil cooler lines come out, can you run the oil cooler and still do this?
Old Apr 1, 2010 | 03:27 PM
Bo185's Avatar
Just buy this and install werethe stock sender goes then install your sender in it.
http://www.speedwaymotors.com/LS-Ser...ter,20928.html
Old Apr 1, 2010 | 03:38 PM
MillsMotorvation's Avatar
thanks alot!!!
Old Apr 1, 2010 | 07:01 PM
NemeSS's Avatar
they got for head water temp fitting also
Old Apr 1, 2010 | 08:53 PM
Jimbo1367's Avatar
cheaper here. http://www.summitracing.com/parts/ATM-2268/
Old Apr 2, 2010 | 07:14 AM
bfrank79's Avatar
that definately looks easier, thanks
Old Apr 2, 2010 | 10:16 AM
bczee's Avatar
If your doing the cheap budget thing... and going to use the stock location, just take the OEM one, break off the plastic sender part, take the lower part, drill and tap it to the correct sender threads and you have a no cost adapter.
Thats what I have done. I put my Chevelle warning light sender there and have used the F-Body bypass plate to use my aftermarket sender (drill and tap the plugged part). That way I have both the original idiot light and a pressure gauge.
Old Apr 2, 2010 | 04:01 PM
Bo185's Avatar
Damn that's cheap!!!! I love it!!!!
Old Apr 2, 2010 | 04:18 PM
1976CamaroGuy's Avatar
I used the thread adapter for my oil pressure unit
and drilled and re-tapped the passenger rear head for my temp sender
Old May 12, 2010 | 09:31 PM
lq46liter's Avatar
How do you get by using the original oil sending outlet? Do you not need to send the oil pressure to the computer also or is that not needed?
Old May 12, 2010 | 09:33 PM
no signal to computer needed...goaes straight to my stock guage
