Three wire alternator not charging.
Of course there has to be a problem. My alternator doesn't seem to be charging at all no matter what RPM I'm at. It's a brand new AC Delco that came with my GMPP accessory drive and it has three wires in the connector. Can someone give me some tips on how to diagnose it? Searching seems to pull up information on the one and two wire alternators. My voltage is around 10.5 to 11.
Can the generic parts stores test this type of alternator?
Thanks!
Search for "Thee alternator" thread and itll get you going. Stock, the alts are controlled by the PCM, but wiring them as a carb car is a simple fail safe method for reliable alt control
I have an LS3 brand new everything in a 57 chevy pickup. I played with it for 2 days and finally someone told me the alternator needed a ground.
I used a #8 wire from the alternator to the block at a threaded hole just above the header. I used yellow wire ends on both ends and crimped them. Now when I start the car the gauge shows 14.3. And before it showed about 12.5.
I tried a #12 wire with alligator clips to various places and they did not work.
The only this works is with the wire securely mounted to the block and the alternator, not the valve covers or anything else. TRY IT
