bellhousing bolts
So do any of you have a part# or know where i can get these things? thanks
The bolts are M10 x 1.5 x 40
If you walk past a GM truck with a V8 on the used lot and give the VIN to the parts department they can get you the parts you need. You could also use the VIN for the engine you have - my scanner can pull the VIN from the PCM, but I got it with the engine from the breakers yard.
