Need Feedback For Ls1 Swap!!
PLEASE HELP MY DREAM BECOME A REALITY...
But, here are the items I can think of:
-Transmission (manual or auto?)
-Converter (if auto)
-bellhousing
-clutch (if manual)
-shifter (if manual)
-driveshaft
-complete LS1 engine
-belt pulleys/idlers
-LS1 computer
-LS1 wiring harness
-Full exhaust system
-alternator
-power steering pump
-A/C compressor bracket
-airbox lid
-LS1 maf
-engine mounts
-LS1 gauge cluster (higher rpm redline)
Its a lot of work and money involved. If you could buy a wrecked V8 f-body for $3000-3500 and have all the parts to do the swap, that would be your best bet.
Tony
http://www.dxsoftware.com/magnus/
awesome information for the swap. since yours is a 98 (LS1 year model) you might not need quite as many parts as he did. Good Luck!
Look on ebay and find some complete packages for sale. Some good sellers are:
AllMustangPerformance-Mustang place but have ls1 packages and Tom will work with you.
Edmerson-fast
fparts-fast and accurate.
After you buy a package let use know what you have and we will tell you what you need. Try and get the motor on the cradle with rack, v6 cradle will not work nor the sterring rack.
Hey what do you mean by...."Try and get the motor on the cradle with rack, v6 cradle will not work nor the sterring rack"....
Thanks.....
http://cgi.ebay.com/ebaymotors/ws/eB...tem=2454675891
The cradle is the black thing the motor is sitting on. The rack is the thing with the plastic boots. The ls1 will not bolt up to a v6 cradle and the v6 rack will not clear the ls1 oil pan. Once the ls1 motor is on the ls1 cradle with rack it will bolt right up.
If you want to do this swap let me know. I part out f-bodies and usually have LS1 engines in stock. The only 98 LS1 I have right now is mated to an automatic. I do have a couple of 2002 LS1's with six speeds available.
