Powertrain Diagnostics Enable wire coming out of E38 ECM
J. J.
Also, isnt that a 24x engine, shouldnt be an E38 if it is an 05. I could be wrong.
Jon
Your Source for LSX Conversion Parts!
www.psiconversion.com
Ebay Store
Facebook/psiconversion
Instagram/psiconversion
'Dont Let EFI Pass You By!'
First, want to appologize, the subject contains a typo. I blieve that I have an E40 ECM, NOT an E38.
It is a white w/black stripe wire in the blue C1 connector position 10 labeled "Powertrain Diagnostic Enable."
I've looked it up in the Alldata wiring schematics for my donor vehicle and can trace it as far as the main power relay. It is the signal wire for the relay which powers all of the injectors, coils, etc. I don't recall at this time if it is + or - though. I will post the diagram tomorrow. I will not be using a main powertrain relay as the stock setup had so I need to figure out what to do with this wire. Ground it, apply power, whatever.
Here's a pic of my ECM:
(Not mine specifically, mine does look exactly liek this though.)
Obviously, the rig isn't running yet. I did temporarily wire up a bench harness to pull my tune out of the ECM with HPTuners so that I could start looking at it and get aquainted. To get it to read the ECM I had to apply power to the wire in quesiton. I don't know for sure that that was the correct thing to do though as there was another wire I was experimenting with at the same time that needed to go to ground. I experimented with both at once and it worked so I don't know if it was applying power to the wire in question that did it, grounding the other wire, or both. I do know for a fact now though that the one I grounded has to be grounded for it to work which leaves this one wire open to question.
Thanks for the help.
J. J.
Looks like its a + wire. My theory is that I just need to run it to 12 + volts or into my ignition switch. I'm new to this though so I guess I'm just looking for verification.
J. J.
Ebay Store
This gets me back to my main question which is, how does the ECM determine when to ground that wire? Does it have some sort of internal diag check that it goes through and if passed, grounds that wire?
J. J.
Jon
Ebay Store
