what do you guys do about state inspections?
hey guys, im debating about doing an LSx/t56 swap into my '92 notchback. one thing thats holding me back is that the car would have to get safety and emissions inspections every year. i know an inspector who would pass it, but dont know how long he'll be around for. the car is likely to be a daily driver, so "passing" inspection is important.
what do you guys do to get your lsx swap car inspected? thanks guys
To be Technically Legal... You need to check your states DMV for re-certification and law/policy for engine swaps.
Most likely if the state permits swaps, You would have to re-cert the car to the engine that is being swapped in and matches the VIN in the PCM.. (vette, camaro, gto, truck, etc..) and be yearly tested as that.
What does VA require for smog tests ? Visual, sniffer, ODBI/II connected and/or dyno ? If it is just a sniffer, you might get away with it. but If it is anythin more..you would fail without re-cert'in the car.
Not sure on VA rules as far as swaps go, but in CA:
In general, the cleanlier you can make your swap, the more inclined an inspector will be to NOT dig into what you did. This means a tidy wiring harness, well routed things, etc... I'm not talking about having chrome everything![Grin](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_grin.gif)
Where people usually run afoul doing engine swaps is one of two things:![Rolleyes](https://ls1tech.com/forums/images/smilies/LS1Tech/rolleyes.gif)
CA doesn't have tech inspections so I have no input for you.
- the engine swapped in has to be the same year OR newer
- the engine swapped in has to retain ALL smog related devices... this means all catalytics, o2 sensors, EGR stuff, smog pump(don't think LS has them), EVERYTHING
- the engine swapped in can not have any NON- CARB approved modifications... this includes headers, intakes, cams, PCM tunes, etc... by CARB, I mean California Air Resource Board not carburetor
Although a carb'd LSx would NOT be allowed in CA either.
- Not buying complete engine and then trying to mix and match parts from other cars.
- Leave stuff off because of "HP gains"... you know, the "I gain 5 hp by leaving off a smog pump" crowd
I didn't even know there was such a thing in Texas. Does this affect you're insurance at all (maybe cheaper)? I wonder how hard this is to do.
The cats need to be placed within 3" in length from the original position on the donor. You also have to use oem cats due to no aftermarket carb approved cats being available.
Truck or suv engines into cars is a big nono.
Yes you need to use all the emission equipment that came with the donor car.
