LSx swap on a budget.....possible?
is it possible to do one of these on a "budget"? if i simply drop in a stock motor, stock trans, and pick up the other incidental parts to make the conversion work on a fox mustang, is there a rule of thumb for a dollar amount? i'm not wanting to do it cheaply, it will be done properly but i'm not looking to do head swaps, cams, stroker kits, etc. What i was actually considering was locating a wrecked GTO and pulling the pieces parts i need from that and simply dropping into the fox. could something like that be accomplished for say $2000-$3000?
after re-reading my post i needed to clarify.......considering buying a GTO and using the pieces i need and then SELLING the pieces i don't need. having cleared that up, would i be able to pull that off for roughly $2000-$3000?
I got my '98 LS1 for $1500 complete, sans trans.
picked up a used T56 for $1200 and the rest of the swap parts for my FC RX7 were about a grand, maybe a little less.
you can really keep costs down by using stock parts, used parts, junkyard barely used parts, etc.
vette fuel filter/regulator instead of aeromotive fpr and expensive hoses and fittings. fbody or taurus v6 radiator and fans, etc. fbody fuel pump and cluch master cylinder, etc. a lot of small but simple fab work for brackets and stuff will keep your costs way down low.
the plan of buying a wrecked LS1 car is THE WAY TO GO on the cheap.
if I do another project car thats the only way I could even afford it.
you can always do a 6L or 5.3L swap to get the swap up and running and in a year or two buy a LS2 shortblock if you find one for cheap, etc.
lots of ways to do a budget build and still do it the right way to so its a beast thats awesome. go for it and have fun man.
if i'm patient enough, i could probably pick up a 6.0 out of a truck for $250 out of the bone yard. i've had people tell me the LS motors are different than the truck line but from what i've read the truck motors can throw down some nasty HP. if they only weigh 65 lbs more than their aluminum brothers and i can save over a grand by using one, i'll go that route.....at least for now. i would just have to buy the car intake, and of course the wire harness. will the t-56 hook up to a truck 6.0? or would have to run the auto trans?
Cheapest way I can figure to go is find a truck 5.3 engine pulled with the harness, accessories, and maybe the automatic. If not, find an automatic that will bolt up, or use an TH350 or TH400 with the flexplate adapter. I spent countless hours and money because I didn't have a complete engine and I ended up switching to corvette accessories (having to find or buy all the bolts and gaskets for everythign adds up quick, if you're leaving the engine alone this part is much cheaper and easier). My next swap will be using all the stock truck stuff (this obviously only applies to cars where the truck accs' fit)
Oh, and check out this thread if you haven't already:
Budget LS engine swap guide
If you're willing to slowly piece the swap together, using a truck 5.3 or 6.0 is a great way to save money and piece it together how YOU want it. A quick swap Id recommend a wrecked car or complete Fbody/GTO dropout
From what i understand, and someone can correct me if i'm wrong, if you swap on a different intake, the truck motors are just as capable of making the same power as the LS series engines, Cube for Cube.
