4 and 5 speeds behind LS1s
I want to throw out a question to you guys. How many of you would be interested in running something besides a T56 behind your LS1s? Would you use a Muncie, Saginaw, T10, TKO, Jerico, Richmond, Liberty, G-Force if it was an easy swap?
Andrew
Using a super T-10 with 2.88 first gear behind my 6 liter LQ4 thats going in my 70 Corvette. Mocked it up the other day with no flywheel to check imput shaft length and it looks like a perfect fit . I think the hardest part will be fabin a mount for the clutch cross shaft on the motor. As soon as it warms up a little I'll get it done.
Its COLD here!!! Stan
I'd be real interested in something that lets me easily switch over to a mini SBC starter (maybe even mounted backwards), and lets me step up to one of the new Tremec TKO 5 speeds (the one rated at 525 lb ft of torque). Its .82 overdrive is far more useful to me than the .5 of the T56 6speed.
Would this allow me to swap over to the proven hydraulic stuff (throwout bearings and such) I see in the various circle track magazines?
John Parsons
Your dream may be a reality soon. If any of you guys are interested in bellhousings with rear mount starters and small diameter clutches, speak up now..LOL...
Andrew
Andrew
Jeff
