which lsx swap kit into a fox is best?
If anybody knows of a different swap kit please post a link or details..
Also if anyone knows the website to go to for the aje or brp kit I would appreciate it..
I've read about these kits threw threads couldn't find their website.would really like to start researching and find the best kit
I used coil overs up front, UPR c/c plates, and stock control arms with poly bushings. I can upgrade to tubular arms later.
The AJE kmember bolted right in, it has lots of clearance, nice piece, priced great also.
$1030 for the engine assembly, computer, harness, intake/exhaust manifolds, mass air meter, alt, water pump, power steering pump, a/c compressor and all hoses
$1400 for the M6 GTO trans
$360 AJE k member and mounts
$150.00 headers Jegs U weld it
$350 for the fuel system, 255 pump, Corvette regulator/filter, aluminum lines,
$320 2008 z06 clutch new
$30.00 ls1 intake
$120.00 Reground Delta cam
$ 60.00 yellow z06 springs
I still need a drive shaft, Abbott cable X, exhaust, misc hoses and a tune
I re used as much as I could from the engine assembly. I would say I am about $2500 to $3000 in the engine swap including the engine.
