My Turn...No Start!
All grounds have been verified. Sensors plugged in, etc.
These injectors have sat since 2003. Could they be stuck shut? I would think I'd at least get a sputter or two.
I'm now wondering if this might have something to do with the "Hot in Crank & Run" issue with the key wiring. Or, maybe the crank sensor. At this point, I'm not sure what comes first. Ideas welcomed.
Oh, I do have AutoTap, but am waiting for a batt for the laptop. Thanks all!
Either hook it up to a hot when cranking circuit, or at least do what bagged said and hot wire the harness to test the theory.
J.
Soaking a stuck/clogged inj in gas is about as effective as ???
A $10 noid lite will tell U if the inj circuit is firing the injs...
I was reading all afternoon yesterday and this seems to be the most direct route.
About soaking in gas or Seafoam...do you soak both ends of the injectors?
I do have a set of 42lb injs which are new, and were bench-flowed about a year ago. In the event that all other tests prove good, would there be a problem with dropping in the 42's, if only on a trial basis?
Thanks!
I had someone crank the engine. There is 12.5v/key 'on' and 10.5v while cranking. This is true on both the coil packs and at the injectors.
Either I'm not getting the inj sig pulse, or there is no grnd. Question...is the inj pulse an opening and closing of grnd as directed by the ECM? How does this work? The drawing shows grnd coming from behind the driver head and supplying the grnds to inj & coils.
Anyhow, the NOID lamp does NOT light when it is applied to the inj. I tried one inj on each bank....same result. Then, the NOID lamp was compared to others in the set to make sure it wasn't defective.
Similarly, no coils will fire.
The VATS box prob isn't an issue as others say it will not prevent the engine from firing, at least for a moment.
I'm still waiting for a batt for my laptop so that AutoTap can be used to examine codes.
Any direction from all of you is welcomed and appreciated.
I'm a little confused about this...what is the process of the inj pulse? If batt and grnd are always present, what electrical property from the ECM triggers the inj to open? How does the electrical state change to 'fire' it? I'd like to know this, but it will prob be a moot point if I find a missing grnd which fixes the trbl.
The grounds on the back of the head are the ground path the PCM closes to...so they need to be attached properly, and the block properly grounded to the frame, or you get no injector pulse and no spark.
This makes sense now, & I see on a schematic that these grnds input to my ECM at RED conn-pins 72 & 76...also BLUE 21 & 60. I'll check these first.
Your description of 'block properly grounded to the frame' made me go over where the ground cables are on the car. I recall that the Neg Batt Cbl is wired directly to my block. The grounds which should be at rear driver's head are all there.
(Goes out to Garage @ 12:45AM/14 deg F...checks a few things)
Alright...there is no direct ground cable between the frame & block, although there IS continuity between them all. That braided grnd which was to connect the block & frame is sitting in a box!
And, it's a good thing that the engine DIDN'T start, because the high pressure line on pwr steer box is seeping a bit/not good. The intense temp change is prob a good thing in that it's showing where things need to be tightened up.
I know it's late, or early, but I'm itching to place a cbl between the frame & engine to see what happens. You think the neighbors will enjoy my open headers at 1AM?
To be continued....thanks again!
Here's where it is...still no start. No inj pulse using NOID lamp & no spark at plugs. Batt to coils & injs both @ "CRANK" & "RUN". BATT volt is 12.5 @ "ON" & 10.75 @ "CRANK". Grounds are definitely there at C#1(RED) 72 & 76...& C#2(BLUE) 21 & 60. Add-on VATS module appears to be functioning. 58lbs fuel @ rail/pump is functioning.
I've just received a battery for my laptop & can now check for codes..ie CRANK sensor. There is also an ocilloscope(sp?) available to me at work. I recall someone in a similar thread saying that his VATS mod was a few cycles off..just enough for it not to work. And then, there's the remote possibility that my ECM is NG.
CAL...I changed my sig just for you, my friend!
In addition, there was the 0335 code for CKP-crankshaft sensor. OK, so maybe the sensor or sensor ckt is the problem. I'm liking this now, as there is a definite maybe for an answer. Then, I cleared the codes just to make sure, and all of the codes came back....except for the CKP. Could be that the CKP is just out of range/at times? Because the code disappeared, I rechecked the NOID light for spark-it was still negative.
It's a bit cold out there today and my hands aren't moving as I would like. That sensor will have to wait until after work, later tonight. Cold cement & I don't mix well.
Thanks for all of your suggestions everyone!
i was tired when i redid mine, and messed two pins up. one was for the ckp, and the other was for the cmp. wighout those it will not fire. mayb somethin to look at
