Pro Street 87' Mazda RX-7
Old 12-15-2010, 09:19 AM
Luke Skyjacker's Avatar
Default Pro Street 87' Mazda RX-7
Hey guys I decided to make a thread to update my progress and hopefully answer some questions I have. Been searching and researching on tech for a while and have really learned alot. The car is an 87' rx7 that has been backhalfed with a 9" ford and ladderbars.
I bought a LQ4 from a van and plan to run it stock via a carburator. I'm hoping this powerplant will be comparable to the 406sbc I had in the car before.
I have ambitions of setting the stock long block n/a record but I have had issues finding such a thread. The car is pretty light (2250) with a 4.56 gear and 295/65/15s out back. I'm hoping I will be at least close.
Old 12-15-2010, 09:27 AM
sbc setup from 07'
^^^^last years attempt (motor blew so it went back under the knife)
when the car looked like that^ it had this motor:
Old 12-15-2010, 09:52 AM
Pictures of some of this years modifications:
http://www.horsepowerjunkies.com/for...d.php?t=102976
pics and updates from 2007:
http://www.horsepowerjunkies.com/for...ad.php?t=56712
pics from 08/09:
http://www.horsepowerjunkies.com/for...t=67409&page=2
Old 12-15-2010, 10:11 AM
This vid might still work, 10.28 @ 130 with the 406sbc
http://www.myspace.com/video/vid/2038977920
Old 12-16-2010, 10:28 AM
Any input on the stock 6.0 record? Stock long block ls record? I did some searching but could only find vette and fbody records.
Old 12-16-2010, 10:15 PM
digitalsolo's Avatar
The only stock block record that I'm aware of is boosted, which is a 1st gen RX7.
Nice car, BTW, good luck with the performance goals.
Old 12-17-2010, 01:02 AM
skinnies's Avatar
Old 12-17-2010, 08:23 AM
From last nite.....
Old 12-17-2010, 10:14 AM
BLNLS1/RX7's Avatar
Keep us updated.
Old 12-17-2010, 12:51 PM
http://s213.photobucket.com/albums/c...ostreet%20RX7/
photobucket link to pics, not in chronological order
Old 12-18-2010, 03:06 PM
WeeWolf's Avatar
Your car is back-halved isn't it?
Old 12-19-2010, 10:47 AM
Sure is. Ladder bars, double adjustable coil overs on a 9" ford
Old 12-19-2010, 11:49 AM
96 Comp T/A's Avatar
Did you buy that nose as a 1 Piece, or make it yourself? Mine's got an add on kit, which I am not super fond of, the nose is passible though.
Old 12-19-2010, 12:07 PM
The bumper came from California via ebay. i think it was designd for wide style front fenders. i was expecting it to bolt righ up with minimal body filler. it was way off! about 4-5" too wide at the front of the wheel wells on each side. it was awful. i had to cut it up and cut my fenders then use counter sunk bolts to attatch the bumper to the brackets i welded on my fenders. hers a few pics, wish i woul hve got some before i started cutting the bumper!
My G/F doing the body ork.... i dont have the patience for the body filler.
Old 12-19-2010, 12:10 PM
Old 12-19-2010, 01:39 PM
mactizen's Avatar
Norotors.com in the drag racing section has a good list going, not all are lsx based swaps however. Guy that goes by skinnies went 8.9x with a basically stock 5.3 on boost. I went 9.68 on a h/c/i ls2 with a 100 shot and you're a good bit lighter then me.
Old 12-19-2010, 08:07 PM
You should definitely post this up over on NoRotors.com
Old 12-19-2010, 08:25 PM
Just registered. Was an active member on Torquecentral.com back in the day, i was on v8rx7forum.com also. i guess it was just a matter of time. lol
Old 05-04-2011, 09:36 AM
Update: fired this thing up this week. Sounds real good. I decided to go blowthru turbo. Motor is bone stock 2006 lq4. Didn't even change the pan. Stainless 2.5" up pipes welded to truck manifolds. Turbo is a Garret TA51 (71mm). 4" open downpipe exits behind starter. Large intercooler and 4" charge pipe. Still need to finish up a few things and get the carb setup for boost.dum
Old 05-04-2011, 09:43 AM
Quick Reply: Pro Street 87' Mazda RX-7
