LQ4/T56 into my 69 Camaro
#1023
After you wired and rewired your swap in, this plug and play will be a piece of cake for you. If I have any patience left I would be happy to help you out. The good thing about the a/c install is you can start and stop at any time. Since it is a standalone system there is no rush on anything.
#1025
![Grin](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_grin.gif)
#1027
I can wire anything. I have yet to find something I couldn't solve. Multiplexing, etc. I can handle. But something as simple as this bracket is so difficult to come out that nice. And I've seen tons of other stuff from folks that THINK they have skills. We all make something that works, but it's rare to find someone who can make it look like it was stamped at a factory somewhere. What a difference.
#1028
Oldcobraguy I appreciate the compliment. I am mediocre at best, just good at hiding my major flaws. I have a secret advantage, I drink beer and therefore have the cardboard from the 18 packs to use as a template. I always cut out a template before making anything. It helps to have collected tools for the past 23 years too. I only buy what I need but after working on this and that for the past 23 years it has compiled into something that I rarely have to buy new tools just replacements that are worn or broke. I am sure after all of the restorations and swaps, you too do an excellent job at whatever you come across. I cant wait to see some of your future projects and I do value your opinion.
#1029
I got the gauges back in there spot and snugged up.
[IMG]
[/IMG]
Trans tunnel cover is screwed down.
[IMG]
[/IMG]
I went ahead and covered the cover with insulation to prevent unwanted heat and noise.
[IMG]
[/IMG]
Rerun my speaker wire and used the insulation to position it away from any sharp edges or interference from the rear seat. I had an amp in the car but it caused alot of engine noise in the sound system. I opted to go the simple route.
[IMG]
[/IMG]
Rear seat divider installed.
[IMG]
[/IMG]
Rear seat back in. As you can tell I am not the best at reupholstering. I needed to add more batting to take out the wrinkles but oh well. I dont ride back there anyway.
[IMG]
[/IMG]
This is a shot of the trunk prior to me getting rid of the surface rust. I originally sand blasted the trunk, etch primed and prime and sealed it but for some reason the trunk leaks when I wash it and the rubber mat just holds onto the water causing the rust. I sanded it, painted it with engine paint, and then laid on a new coat of spatter paint.
[IMG]
[/IMG]
Here is an after shot.
[IMG]
[/IMG]
[IMG]
[/IMG]
The wiring under the dash is complete and most of the interior is in. I put new carpet up front since my shifter location is in a different position now. The kick panels, radio, gauges, wire protectors, door sills, back seat, OBDII, and whatever else is in its permanent location.
[IMG]
[/IMG]
[IMG]
[/IMG]
[IMG]
[/IMG]
[IMG]
[/IMG]
[IMG]
[/IMG]
[IMG]
[/IMG]
[IMG]
[/IMG]
Thats it for today. I will resume with the under the hood activities tomorrow. Hopefully my hard line will come in and I can at least get the loose ends buttoned up on the A/C unit. I will however need to mark and cut the rubber lines to have the ends crimped on. Then its off to the shop to get the evacuation and charge. If all goes well it will be rear end time by the end of the week.
[IMG]
![](http://i1233.photobucket.com/albums/ff394/tsnow678/001-37.jpg)
[IMG]
![](http://i1233.photobucket.com/albums/ff394/tsnow678/002-27.jpg)
[IMG]
![](http://i1233.photobucket.com/albums/ff394/tsnow678/003-29.jpg)
[IMG]
![](http://i1233.photobucket.com/albums/ff394/tsnow678/004-25.jpg)
[IMG]
![](http://i1233.photobucket.com/albums/ff394/tsnow678/005-29.jpg)
[IMG]
![](http://i1233.photobucket.com/albums/ff394/tsnow678/006-24.jpg)
[IMG]
![](http://i1233.photobucket.com/albums/ff394/tsnow678/007-24.jpg)
[IMG]
![](http://i1233.photobucket.com/albums/ff394/tsnow678/008-21.jpg)
[IMG]
![](http://i1233.photobucket.com/albums/ff394/tsnow678/009-23.jpg)
[IMG]
![](http://i1233.photobucket.com/albums/ff394/tsnow678/010-19.jpg)
[IMG]
![](http://i1233.photobucket.com/albums/ff394/tsnow678/012-14.jpg)
[IMG]
![](http://i1233.photobucket.com/albums/ff394/tsnow678/013-12.jpg)
[IMG]
![](http://i1233.photobucket.com/albums/ff394/tsnow678/014-7.jpg)
[IMG]
![](http://i1233.photobucket.com/albums/ff394/tsnow678/015-8.jpg)
[IMG]
![](http://i1233.photobucket.com/albums/ff394/tsnow678/016-9.jpg)
[IMG]
![](http://i1233.photobucket.com/albums/ff394/tsnow678/018-6.jpg)
#1030
I ordered a new three spoke 15" steering wheel today. Its like the original cushion grip from back in the day but at a third of the cost. I priced the original at the resto shop and it was going to cost $225 for the kit minus the bowite sticker. I got the Grant look alike with the bowtie for $80 and since I already have the three bolt adapter I didnt need to buy the installation kit. It should be in this week from Summit.
#1033
Thanks! Its funny, my interior was originally blue. If you look close you can see the blue bleeding through on the end of the turn signal lever. I used Dupont vinyl dye on some of the original parts to save money and replacing them as I go along. If my line for the a/c comes in today I may grab a new signal lever and rear view mirror. Just curious what color was the exterior of your car from the factory? Mine was paint code 50 Dover White.
#1034
You know what you're going to have to do to fix that leaky trunk don't you??? Somebody is going to have to crawl in with a flash light why you hose it down good.
Betcha it's leaking past the trunk lid seal (maybe under it??) or from the rear window seal. That's pretty common on GM vehicles of this vintage if I recall...and MUST be fixed as it rusts out quite a bit of stuff.
#1038
#1039
#1040
Thanks man! I see you have yours out on the open road, thats awesome!
I do appreciate it! The kick panels look killer and I am sure they will sound just as good as they look.
Thanks Bandit! Did you get the engine location nailed down yet? I see you will be in the clear next month. I hope the best for you and its great to here you didnt give up despite what you have been through.
Tommy69z- you guys have had that car since new? Thats almost unheard of these days!! It feels like I have had mine forever but in actuality I have only had her 17 years.
bmf5150 Looking great!!!
TheBandit- Wow man, you are really on your way. Everything looks great. Bravo!
