LQ4/T56 into my 69 Camaro
Old 07-19-2013, 09:53 PM
  #1781
GC99TA's Avatar
Originally Posted by tsnow678
What happened to your sig?
Don't know? I'm on my phone so I hadn't noticed. I mast have accidentally turned it off. I'm riding in my buddies car on the way home from the drag strip.
Old 07-19-2013, 09:54 PM
  #1782
GC99TA's Avatar
Looks like its back. Switched from mobile mode to classic.
Old 07-19-2013, 10:19 PM
  #1783
tsnow678's Avatar
Who run? You? Yeah its back to normal!
Old 07-19-2013, 10:38 PM
  #1784
GC99TA's Avatar
Nah, we just went to watch. I'm up in PA so we went to Pittsburgh Raceway Park.
Old 08-02-2013, 11:13 PM
  #1785
futureuser's Avatar
Those are the same size slicks I was using. You should do well with them and have no issues. 'Looking forward to seeing you at the track.
Old 11-05-2013, 02:44 PM
  #1786
rs67ss350ac12bolt's Avatar
great looking car. I picked up quite a few tips from your 3 yr build. I am putting a LM7 in a 67 so I'm always looking to see what works. I should have done this a long time ago.
Old 11-05-2013, 06:17 PM
  #1787
tsnow678's Avatar
I am glad someone still reads this old thread. I am about to add a little bit to it in the coming weeks. Not necessarily LS mods but more of an upgrade to components that will help my car handle the current power level better.
You will love the power and reliability of the LS family! My car is at a whole different level with the current engine and supporting components. I still have a bunch of things I would like to do at this point but I am sort of focused in one direction right now. I want some low 7 passes on the engine if possible and then maybe a little spray.
Do you have a build thread started?
Old 11-08-2013, 01:50 PM
  #1788
DON Kenyon's Avatar
Hello tsnow678, your photos shot great detail and quality of workmanship. This is exactly what i will do with this lq4 6 l i have just purchased. Please advise me what ecu and wiring harness you plan to use--price, who sell it, etc thanks don 585-352-1165. I'm doing a tube chassis for drag racing /street. Turbo 350/ brake/9 inch. Thanks don 585-352-1165
Old 11-08-2013, 03:52 PM
  #1789
tsnow678's Avatar
Thanks Don! The PCM I used was from a 2000 Camaro LS1 and the wiring harness was built by Street and Sand Performance(SSP). I personally like Steve from SSP but there is some debate on whether or not he is reliable. He was one of the few people that stepped up and helped me diagnose an issue I had with my current engine. He did so with out any vested interest in the problem. All around a great guy! I bought the custom harness with the aviation loom and fuse block prewired in, PCM(re-flashed to my specs), and MAF for approximately $600-650. If that doesn't work out for you check with Alvin Anderson at PCM of NC. Alvin is real good with mail order tunes and can supply you with the correct PCM, wiring harness or what not. Sounds like you are putting together a fast ride. Have you started a build thread yet?
Old 12-30-2013, 07:30 PM
  #1790
tsnow678's Avatar
I know it has been a while since my last update. I ran my car in the 1/8th on my everyday street tires and didn't fare so well. Coming out of the hole at idle really kills your 60 foot. I did manage to run a 7.89 @ 93mph. I know not too impressive but given the temps, track condition, and the use of street tires I felt like it was ok. I made up my mind that if I was going to run my slicks I would like to do so with a beefier rear end. I know there is much debate on how much power a 8.5" 10 bolt will hold. I really don't like the idea of the axles only being held in by the c-clips. And it is suggested not to run c-clip eliminators on the street. So my only options were either not to run at the track again or bite the bullet and build a 9" rear. Needless to say I chose to build the rear. I had purchased the 9" rear from a guy in Charlotte for $75 complete out of a 79 Ford F-100 4x4. Naturally it was too wide for my application but it was wide enough for me to cut it down to center the housing to the car. IIRC Ford offsets the housing by 2" and the pinion by 4" to allow for equal length axles. I measured this damn rear about 100 times, compared the results to the existing rear in the car, verified the correct parts were available to complete everything, etc. etc. Here are a series of pics from start to finish.
Old 12-30-2013, 07:32 PM
  #1791
tsnow678's Avatar
This is what a $75 rear end looks like.[IMG][/IMG]
Old 12-30-2013, 07:33 PM
  #1792
tsnow678's Avatar
Gutted![IMG][/IMG]
Old 12-30-2013, 07:42 PM
  #1793
tsnow678's Avatar
Pretty cool tool to measure key points on the rear end. I also purchased their pucks to align the housing ends with the axle tubes. Fortunately for me I work at a machine shop so I was able to order a slick piece of 1-1/4" round 12L14 bar.
[IMG][/IMG]
Old 12-30-2013, 07:44 PM
  #1794
tsnow678's Avatar
All the old brackets are ground off and the outside surfaces were smoothed off. The top side is closest in this pic. Notice the rear end ruler in place.
[IMG][/IMG]
  #1795
Old School Heavy
speedtigger's Avatar
93 MPH is actually pretty good for first time out. That is enough MPH to show the car will run into the 11s.
Lots of guys run as fast as 9 seconds with the 8.5". It is an underrated piece, but if I had a stick shift like you, I can see the appeal of the 9". I have to say though. By the time that 9" is actually done, you will have some coin in it for sure. Check out the 60 series complete rears from Strange. I think they are a real bargain.
Old 12-30-2013, 07:45 PM
  #1796
tsnow678's Avatar
With the rear end leveled and locked into the chop saw it was time to start whacking off the old ends.
[IMG][/IMG]
Old 12-30-2013, 07:56 PM
  #1797
tsnow678's Avatar
GM passenger housing ends that use the 3.150" Ford big bearings (Moser #7900), All Star fill cap with bung, Moser flush drain, and a new transmission mount.
[IMG][/IMG]
The reason for the new trans mount...
[IMG][/IMG]
Old 12-30-2013, 08:00 PM
  #1798
Old School Heavy
Do you have the jig for locating the new axle ends?
Old 12-30-2013, 08:10 PM
  #1799
tsnow678's Avatar
I purchased a set of rear disc bakes off of the S10 series trucks/blazers. I like the parking brake assemblies better than the Seville calipers like I had on the 10 bolt. In no way will the parking brake adjustment have any affect on the brake pedal height. I must say the brake pedal feels much better with the S10 setup. Here I am boring the ID to allow the axle bearing to slip through the backing plate and dust shield.
[IMG][/IMG]
Flush mount drain plug in place
[IMG][/IMG]
Grinding down the spacers that go between the axle bearing and the retaining plate. I left .040" so that the retainer would actually put a little tension on the outside bearing race.
[IMG][/IMG]
Old 12-30-2013, 08:13 PM
  #1800
tsnow678's Avatar
Yes! I have a slick 1-1/4" rd. 12L14 piece of material 5 foot long and the pucks for the center section along with the pucks for the housing ends. I was actually surprised as to how far out the housing was after the old ends were cut off. Not an easy task trying to straighten an axle tube that is .200" thick! I had to use some heat and gentle persuasion but she is dead nuts straight from end to end.
Quick Reply: LQ4/T56 into my 69 Camaro
