Stans 1968 camaro LS swap and other upgrades!
Old 04-19-2011, 08:50 PM
  #321
bmf5150's Avatar
Wish I new about battery sooner,I bought a billet battery mount made for an optima!!oh well
Old 04-19-2011, 08:51 PM
  #322
bmf5150's Avatar
Thanks for the info
Old 04-21-2011, 06:01 PM
  #323
tsnow678's Avatar
Yeah I second the thanks on the battery information. I will have to make up my mind in the next couple of weeks. The AGM gets rather expensive as you move up in the cranking amps. It seems if you could get by with the smaller batteries the cost is less and the size is alot smaller. Alot of information to think about.
Old 04-27-2011, 06:01 PM
  #324
bmf5150's Avatar
Been busy working on the car,finishing all last minute details!!I got my new tail housing installed on the trans which will drive the speedo gear!got all hoses on thanks to tsnow for the hose part numbers!went and took my driveshaft to get modified,should be ready Friday!!I hope to be filling all the fluids this weekend!maybe start up this weekend or next!
Old 04-28-2011, 12:46 AM
  #325
IntercooledC6's Avatar
Wow, your car is coming together real nice. I was wondering the total est cost of your conversion. I know you aren't completely finished. I am in the works of starting my 68 SS/RS muncie 4 speed to LS1 T56 swap. I have a few Lsx , So I know what they are capable of.
Good Job..
Old 04-28-2011, 11:09 AM
  #326
bmf5150's Avatar
I'm going to guess at this point,I would have to add it up!13,000.00
Old 04-28-2011, 11:54 AM
  #327
Was you able to retain the OBD diagnostics port? If so, Did the port come with the harness?
Thanks larry
Old 04-28-2011, 01:44 PM
  #328
bmf5150's Avatar
Yes u keep it and yes it's on the harness,just tell S&P how long u need it
Old 04-28-2011, 02:26 PM
  #329
tsnow678's Avatar
Yeah when I started my swap I was hoping for the $4500 range boy was I way off. I am at $9000 and counting.
Old 04-28-2011, 03:18 PM
  #330
bmf5150's Avatar
Yeah,could have saved money in places if I wanted to,but I went with stuff that I researched that worked together!
Old 04-28-2011, 03:20 PM
  #331
bmf5150's Avatar
I just hope when I fire it up I have no leaks or ticks or major problems!!
Old 04-28-2011, 08:20 PM
  #332
tsnow678's Avatar
You and me both! I just checked the ohms of the Ford fuel pump and it is 15-165 so when I get the Dakota digital gauges I will know what to program in. I am seeing daylight from the other projects so you better hurry up if you want to beat me to the finish line. I wish you the best of luck and with your attention to detail I dont think you have anything to worry about.
Old 04-29-2011, 05:48 PM
  #333
bmf5150's Avatar
I hope I don't!!I can't find any local 4 inch tubing for my air intake,may try the route u went with with PVC!
Old 04-29-2011, 07:54 PM
  #334
tsnow678's Avatar
Oreillys has a system with the tubing and filter for $135-$145. I think it is 4" and has an elbow. I am out around $45 for the tubing and couplers and $25 for the filter. Half price and solid as a rock. Everyone that has come by didnt even notice the tubing until I pointed it out. As soon as I asked if they knew what it was they all guessed it right. They said they would have never noticed it had I not said something. Its seems as if it will make for good insulation against the engine compartment heat too. I havent glued mine yet as I am unsure at this point if I am going to remove the washer bottle and run the air filter into the void between the fender and the inner fender with some kind of plate to further block out heat. It will prolly run quieter that way too, not that is a good thing as I like noise!!!
Old 04-29-2011, 08:16 PM
  #335
bmf5150's Avatar
Do u have a stock throttle body or bigger?
Old 04-30-2011, 04:32 PM
  #336
tsnow678's Avatar
I have a 96mm Professional Products throttle body. I forgot you were using the stocker. You should still be able to figure out something from Lowes. My throttle blade alone is almost 4" in diameter so that makes the housing bigger of course.
Old 04-30-2011, 06:17 PM
  #337
bmf5150's Avatar
Yeah ,need to figure out sonething
Old 05-03-2011, 03:25 PM
  #338
bmf5150's Avatar
Well I ordered my air intake from oreilly autoparts!!I need to put the return power steering line on,plug wires on and put some gas in her and fire her up!hopefully in the next day or so I will have it running!!
Old 05-03-2011, 03:59 PM
  #339
tsnow678's Avatar
Good deal! Cant wait. I actually got started back on mine last night. If it wasnt for you guys I would prolly be lazy and take a break. Thanks!!!
Old 05-03-2011, 04:18 PM
  #340
bmf5150's Avatar
Yeah I tried the PVC,just to big for my stock throttle body!!I also have a drip on the seal from my trans where I replace the tail housing for the mechanical speedo !look like that will have to come back apart to,prob just use that black RTV on it!
Quick Reply: Stans 1968 camaro LS swap and other upgrades!
