Stans 1968 camaro LS swap and other upgrades!
#346
make sure coil harnesses are plugged in correctly, you would think this was impossible to screw up but I had to learn the hard way, mine was doing the exact same thing.
#349
verify your ign switched is 12v.. if you used the coil wire it prob still has the resistor wire in it.. then you only get 8v and it will start and die like you describe.
#351
Thanks matt for the advice,we wired it at fuse box under dash!my bud Jeremy who knows more about wiring took care of it for me!I doubled checked that I was getting voutage at the computer in the run position of the switch!I was getting 13 volts!I have a friend that's has HP tuner on a lap top coming over tO check it out in the next few days!I really hope it's the vats!
#353
Woohoo!!!my car runs!!!it was the vats!!!!big thanks to my buddy Dave for bringing his laptop over with HP tuners on it!!I guess S&P forgot to turn it off!!!!I guess they used a program from a 2000 camaro
#354
#356
I have to take the rear tail housing back off of my trans ,it's leaking slightly!other than that need to finish filling trans up with trans fluid and check close for any leaks!!
#360
You will have to go in from the bottom on the drivers side. Every set of headers I have used on the drivers side went in from the bottom. The passenger side slides right in from the top. I ended up having to remove my steering box to get it in. The spark plugs even caused some interference.
Chris
