LQ4 injectors w/ .600 lift
The following users liked this post:
97obs_ls (01-26-2022)
I was mistaken, the 8.1 injectors are 46lb/hr not 42's. Here's where I got it from, http://www.vetteweb.com/features/vem...ine_build.html
"Ultimately (and obviously), everything came together. The C5's ECM (computer) and the Vortec 8100 V-8 are compatible-once the right injectors were determined. The 8.1 comes with 46 lb/hr gushers while an LS1 has 26 pounders. It ran way too rich on the 8.1L's nozzles, and after much trial and error, Hofer found the LS1 injectors are not only completely adequate for the mega motor but it also runs perfectly on them".
If you are using stock truck fuel rail, intake and wiring harness, IMO, your best bet is to send your injectors off, and have them re-worked to about a 40lb injector (or whatever you decide to use). The only other direct-fit option I am aware of is the 8.1 marine injectors. The good thing about having your stockers re-worked is that you'll have all the data that goes along with them, and the cost is about the same, or maybe less than buying 8 new injectors.
I forget who offers this service, but they are a sponsor here (I think...) maybe fuelinjectorconnection.com or something like that.
If you go too big it won't be as good of a spray pattern at minimum pulse widths. However, a 42lb injector isn't very hard to tune and you would have room to grow.
