hooking an LQ4 to a Th350?
nice. your good,although you may have to open up the converter bolt holes on the flywheel. don't panic though, the nose of the converter centers it. you'll be missing a bolt on the bellhousing block arrangement, but i suspect you know that. it would be a good idea to test fit the converter to the flywheel and the trans to the block. unless the trans is in the car. if it is at least test the converter to the flywheel. sweet you even got the exhaust flanges.
The only hole i had to open up on my 4L80 flexplate is the smaller locating hole, dont get crazy with the drill though. The 6.0 ltr/4L80 flexplate has the bigger(T400) bolt circle so make sure you order a converter accordingly because the smaller(T350) bolt circle wont work.
