Where to mount the Abbott Cable X on GM A body
I am finally getting around to installing my Cable X. The best place I've found is above the heater core box behind the glove box. It has plenty of space there but seems really difficult to get fasteners (screw or nuts and bolts) in that tight area. Ideas are welcome.
I was playing around with the setup today. I mounted it on the heater box behind the glove box but the motor makes too much noise and my needle was jumpiing up and down during my tests. I this it was becuase the cable was binding too much.
I was told that another member had put it under the drivers fender with good result. He mentioned cutting the cable and making it as straight as possible. He also mentioned lubing the speedo too. This installion method seems to be more complex but it looks like that is the way I'm going to go. More ideas are welcome.
try replacing the cables with some new ones. most speedo/electic shops will custom make you one to your spec's.. and its not that costly. Might help on any dried out cable and kinked ones.
How about wrapping it in some sound installation ? or box it up if you can.
Not sure how big it is.. but.. how about on the wheel well but under the fender, i know i run wires under there... or up by the horn relay. ?
The cable is brand new. I'm not sure if it comes lubed but I'm assuming it already has grease in there. The route I took had one wide bend in it.
I like the idea about insulating the motor. I can maybe wrap it in dynamat.
Mine is mounted to the heater box . Mine jumps at slow speeds and it also makes noise. I think it is the nature of the beast but I am not sure. I spent alot of money on it for it to work like it does. It is even the updated one. I have just been using my gps for long trips.
I had one of these on my old G-body Cutlass. I put at least 50K miles on it with no trouble. I did figure out that the cable has to be as straight as possible. I mounted it on the driver's side fenderwell. It worked great mounted in that location.
