LS7 Syclone
Old 04-01-2011, 11:41 PM
TurboV6's Avatar
Default LS7 Syclone
Just putting a quick post up of my project. I will not be updating it a ton as any spare time I have will be in the garage working on the truck. I will be uploading pics on Photorbucket here.http://s266.photobucket.com/albums/i...ndy%20Syclone/
The build is as follows.
LS7 out of a 2007 Z06
Diamond forged pistons
Hand ported the heads
Cut the heads to 67CC
Cometic 0.040 head gaskets
compresson is 11.9-1
Fast 102 intake and throttl body
Stock crank and Ti rods
ARP main studs, heads studs
ARP rod bolts.
comp Cam 246/254 116+5 .620 lift
JP billet double roller timing chain
Stock rocker with comp bearing upgrade
Melling oil pump
RPM oilpan
RPM 1 7/8 long tube headers
Short 60lbs injectors with Fast rails
0411 ECM set up to run 4L80e
Motor dynoed out at 675hp 590lbs and made 470lbs at 2400rpm.
Trans is a built 4L80e with Circle D triple disk converter.
Plan is to drag, road race, autocross, cruze just wear the damn thing out.
I will be staring the install of the 4 link in the back soon and will be taking pics.
Nolan
Old 04-01-2011, 11:48 PM
Irish350's Avatar
dude you gotta keep this thing bumped
looks like a very cool build
Old 04-01-2011, 11:53 PM
TurboV6's Avatar
Dyno vid. Low rpm to get specs for circle D to build me a converter.
http://s266.photobucket.com/albums/i...t=MVI_1585.mp4
Nolan
Old 04-02-2011, 06:25 PM
squee's Avatar
I'm gonna be doing the same pretty soon with my Syclone. Only difference is I will probably just go with a cammed motor, then go with a Kenne Bell when I can afford it. What swap parts did you use? Motor mounts, tranny crossmember, headers, etc?
Old 04-03-2011, 09:31 PM
Boostedhatch's Avatar
Will you be keeping the awd?
Old 04-03-2011, 09:47 PM
eviltwin_1987's Avatar
yes he will
Old 04-04-2011, 12:27 AM
One Bad Duramax's Avatar
this is going to be so sexy
Old 04-04-2011, 06:04 AM
BoostedLQ9SS's Avatar
RaceProvenMotors out of California makes Pans, Custom N/A or Turbo Headers and Mounts for the motor.
Ralph
http://raceprovenmotors.com/v2/syty/rpminc.php
Mike sells everything for these trucks, custom or general
Old 04-04-2011, 10:39 PM
crankstart's Avatar
is this the first REAL cyclone ls swap?
Old 04-04-2011, 10:48 PM
ivan_key's Avatar
No there's more of them with ls engines
Old 04-05-2011, 06:32 AM
squee's Avatar
Not to mention its Syclone...
Old 04-05-2011, 12:21 PM
Jones'n's Avatar
If you intend to drag, road race, and motorcross... why would you get rid of the dry sump?
Old 04-05-2011, 04:41 PM
TurboV6's Avatar
Fitting the pan and system on the truck would have been a whole ton of fab work as the front diff makes it tight. I also highly doubt even on its best day the truck will come close to pulling the G's of the Z06. I am putting a accusump on the truck and if I find I am getting that serious about road racing and getting fast times I most likly will just get a vette.
Nolan
Old 04-10-2011, 01:31 AM
TurboV6's Avatar
Default somre more progress
Made some more progress. It goes slow 2 hours a night after the kids go to bed but I am chipping away at it if I do not fall asleep after reading Berenstain Bears.. Headers are in, oil lines, power steering lines, engine wiring.
Tomarrow the tranny and tcase are going in. Then I will set up ride height, after that is set I will pull off the bed to start on the 4 link.
Here are some pics. I uploaded some more pics to the photobucket.
There are more pics at photobucket http://s266.photobucket.com/albums/i...ndy%20Syclone/
You will see my version of a light weight rad support on those pics as well.
HHHHMMMMMMM should I paint the rad black as well???
Nolan
Old 04-10-2011, 11:16 PM
scalarrthu's Avatar
Nolan, glad to see things are getting going on this swap...unlike mine which is still at a standstill (as you can probably tell since you're still not tuning on mine ).
Looks like I'll probably be back up that way for a visit come late June (for the races), and will swing by the shop again to say hello... Keep up the awesome work on the Sy!
-Paul
P.S. Weren't there some parts I was wanting to buy off of you???
Old 04-11-2011, 02:26 AM
Irish350's Avatar
verrry clean
does someone like braided wrap?
Old 04-11-2011, 08:53 PM
Strokinit383's Avatar
Sweet truck!
Quick Reply: LS7 Syclone
