Oil prelube new engine
Old 04-06-2011, 06:01 AM
wanderlodge's Avatar
Angry Oil prelube new engine
Anybody know where and how to prelube a new crate motor I assume I pump oil in somewhere filter sending unit any help would be appreciated
Old 04-06-2011, 07:09 AM
46Coupe's Avatar
https://ls1tech.com/forums/generatio...-oil-pump.html
Old 04-06-2011, 08:21 AM
lizeec's Avatar
Default Melling
Melling MPL-101 - Melling Pre-Lube Engine Oiler
Melling #MPL-101
There is a port right below the coolant temperature sensor where you feed the pressurized oil in.
Old 04-06-2011, 11:00 AM
Marky522's Avatar
You can use a yard sprayer, there cheap... you will just need to adapt the hose which isnt too hard. I use my pressure brake bleeder, just clean it out really well first.
Mark
Old 04-06-2011, 11:02 AM
fast400's Avatar
You can make your own pre-luber. Buy a cheap fluid pump, in my case an old fuel pump. Find the plug you'd normally hood your pre-oiler to (driver-side block below spark #1). I screwed in a fitting, hooked the hose to it, then pump, then the other end into a new qt of oil. Then give it power until you get pressure....Done!
Old 04-06-2011, 06:48 PM
Pop N Wood's Avatar
Or you can do what GM says to do when starting their new crate motors. Pull the plugs, disable the fuel and crank the motor over for 10 seconds at a time until you register oil pressure.
EDIT: orignally said 30 sec, but the instruction says 10 seconds.
Old 04-06-2011, 08:07 PM
Gray86hatch's Avatar
I use a $55 moroso accumulator
put a 1.5 qt in it and hit it with a little air to push it thru the motor.
quick and easy
Tim
Old 04-06-2011, 08:29 PM
71ANTICARB's Avatar
Originally Posted by Pop N Wood
Or you can do what GM says to do when starting their new crate motors. Pull the plugs and crank the motor over for 30 seconds at a time until you register oil pressure.
That's what I did.
Old 04-07-2011, 01:35 AM
PlatnumStatuz's Avatar
a couple psi of air into the case, and crank with no plugs or fuel relay
Old 04-07-2011, 08:12 AM
Pop N Wood's Avatar
Originally Posted by 71ANTICARB
"A government big enough to give you everything you want is a government big enough to take from you everything you have." Gerald Ford..
I thought that was Thomas Jefferson or one of the other founding fathers?
One of my all time favorite quotes.
Old 04-07-2011, 10:41 AM
71ANTICARB's Avatar
Nope it was Ford in a presidential address Aug 12 1974 but is often misattributed to Mr. Jefferson and Barry Goldwater.
But yes still a favorite and true none the less.
Old 04-21-2011, 11:13 AM
The Big Al's Avatar
Gm does not have this instruction on any LS engine.
LS engines the pump is located in timing cover. So it is dry, it is not submerged in the oil pan.
They need to be primed.
And when dealing with a dry/wet sump IE: LS7 it is most important.
No where does GM have this instruction.
Al
Old 04-21-2011, 11:29 AM
Pop N Wood's Avatar
Al
Look at page 5, items 2 & 3 of this GM installation guide. this one is for an LS9 but they have similar guides for all their other LS crate motors.
http://www.gmperformanceparts.com/_r...ngines/LS9.pdf
Old 04-21-2011, 11:55 AM
RATBOX's Avatar
That's all I did on mine, was zing it over till it pumped oil through out.
Old 04-21-2011, 12:06 PM
LSCha0s's Avatar
I think i will Zing it
Old 04-21-2011, 12:50 PM
chuckd71's Avatar
I zung? zang? (past tense?) mine a day or two ago. Took a while but eventually I got some to the mech oil press gauge and under the valve covers. Still think I'll pop them both off and pour some oil in there before my first real start.
Old 04-21-2011, 02:50 PM
FastKat's Avatar
Doesn't it already come prelubed with engine assembly lube?! I thought that stuff would keep the bearings safe for the 2 seconds it takes the oil pump to get pressure up to the top of the engine. Make sure your oil filter is filled with oil. That will make a significant difference.
When you're ready to run the engine for the first time, fill the oil filter with oil and start the engine.
Old 05-29-2011, 05:02 PM
foler's Avatar
quick and easy
Tim
some video about this?
I am really confused about this. Any video how to prime NEW crate LS3 engine installed in the car? I dont want crank engine without priming with oil. But how to force oil circulation without rotating crank??? Sorry I am not mechanic but know that bearings can be destroyed in miliseconds without oil pressure.
Old 05-31-2011, 03:16 PM
shoemike's Avatar
http://www.youtube.com/watch?v=tOYLl...layer_embedded
Old 05-31-2011, 06:03 PM
Pop N Wood's Avatar
Nahh. Obviously not true.
Here are the directions that GM publishes for their NEW LS3 crate motors. It includes detailed instructions on how to prelube NEW motors.
http://www.gmperformanceparts.com/_r.../LS376-480.pdf
Quick Reply: Oil prelube new engine
