95 s10 lq9
Old Apr 6, 2011 | 08:54 PM
ls1cutlass's Avatar
Default 95 s10 lq9
Iam doing an s10 lq9 swap i have a guestion i really need some advise motor mounts iam using are ajustable. I should try to center my motor in the frame right? I thought i should at least iam trying to. Is it very critical how i do this? Right now its a little over a 1/4 inch from being center. I am measuring center off inside of fram and off the front crank bolt. My mounts are cpw ill try to get pics up i have them on the camera but dont know how to put them up on this site. Thanks for the help
Old Apr 6, 2011 | 09:32 PM
5.3blazer's Avatar
i used trans adapt mounts on mine,mounted mine on the bottom holes lined up good
Old Apr 6, 2011 | 09:37 PM
ss454327's Avatar
Current Performance has a set of poly mounts that work great. That's what I have on mine. I'm putting together the fuel system in my '96 right now. It would be easier if I had used the stock tank but I wanted a tank behind the axle for added weight at the rear. These trucks are notorious for not hooking even with caltrac bars and ET streets.
Old Apr 6, 2011 | 09:50 PM
ls1cutlass's Avatar
Default 95 s10 lq9
Yeah but did you guys just put the motor in and tighten it down i have to make sure say the motor not off to one side not in the middle did you guys check that. i mean had no problem gettin everthing in but the motor will move side to side right well do i make sure its in the middle eyeball it or measure and make sure its centered
Old Apr 6, 2011 | 09:53 PM
5.3blazer's Avatar
mine is off to one side a little been driving it for 3 years like that and no problems
Old Apr 6, 2011 | 09:57 PM
ls1cutlass's Avatar
Default 95 s10 lq9
ohh ok so i think iam ok i didnt no if you guys you know measure to make sure its centered what about tranny thanks
Old Apr 6, 2011 | 10:02 PM
crankstart's Avatar
caltracs still don't solve the traction issue?
Old Apr 6, 2011 | 10:04 PM
5.3blazer's Avatar
all the ls s-10's i have seen the engine sits a little to the pass side,not sure why
Old Apr 6, 2011 | 10:07 PM
5.3blazer's Avatar
caltracs and sliders work pretty good on s-10,with drag radial or slick
Old Apr 6, 2011 | 10:18 PM
ls1cutlass's Avatar
Default 95 s10 lq9
So as long as my tranny is centered in the frame and i have the right pinoion angle iam ok? thanks
Old Apr 7, 2011 | 01:06 AM
the_merv's Avatar
My MCSS has the engine sit about 3/4" to the passengers side..the S-10 has pretty much the same front end as a G-body.
I think it's to balance out the driver's weight.
Old Apr 19, 2011 | 10:53 AM
Littlemotor's Avatar
^^^This. So long as the trans is centered and is SQUARE, along w/correct driveshaft/pinion angles, you are good to go.
The mounts are different BECAUSE the frame is NOT symmetrical.
FWIW, Cal-Tracs have put Bobby Flippen's 1st gen in the 4's if I'm not mistaken. Something like a 1.13 60" time too. He runs sliders I believe, but there are PLENTY of folks running shackles and hooking S10's with Cal-Tracs, weight transfer, and simply dialing the set-up in. You cant just bolt them on and jerk the tires.
Old Apr 19, 2011 | 07:03 PM
dogger's Avatar
BTW not all cars have the motor centered in the car I know of a few cars that were designed with the motor off set from the manufacture often to clear the steering shaft
Old Apr 19, 2011 | 07:26 PM
ss454327's Avatar
That was my point...they won't just hook even if you have sticky tires and traction bars. Some people think just slapping on a set of bars and some tires will solve all their problems. A bone stock LQ9 is going to be a beast in an S10.
