Alternator Wiring/Battery Location
I replaced all the fuseable links with fuses. Pretty easy to do and much easier to tell when something cooks.
If I were you I would just hook the alternator output to your starter lug or whatever terminal you have powering your fusebox. If you are racing and need and external kill switch then you may not be able to do it that way. not an issue if you aren't
Admittedly most guys run it straight to the battery, but IMO not the best place.
Save yourself some wire and run it to the fusebox.
Good luck,
Mark
Good luck,
Mark
any help would be greatly appreciated. thanks
fuses come in all different sizes. Once you have the fuse holder you can mix and match fuses as needed. Typically the fuse is sized to the size of the wire, not alternator capacity. Hopefully the wire and alternator size match. In my case the wiring is much bigger than the alternator output, so I used an 85 amp fuse to match the alternator rating. Keep the fuse or fusible link as close to the alternator as possible.
This site shows a table saying to use a 160 amp fuse to protect that size of fusible link. I would be tempted to go with a 130 amp fuse to match your alternator capacity. The biggest maxi fuse I could find is only 100 amp. I went with an ANL fuse and weatherproof holder I got from this place
Honestly, all you really need to do is cut off the 8 gauge wire in your current harness and replace it with a longer one. The only real problem with fusible links is sometimes people forget they are there and when one blows they end up replacing everything before they figure out the real problem.
This is because the voltage drops as the amps travel down the wire. When the voltage drops the amperage goes up (ohms law). If the wire is too small to carry the load it will over heat and possibly cause a fire, not good.
The over current protection device (OCPD) ie. fuse, circuit breaker or fusible link is there only to protect the wire not whats in the other end of it. The OCPD has less current capacity then the wire. When a short circuit occurs the OCPD will fail and its job is done.
You should use an OCPD for all power wires except:
IMPORTANT! Never use an OCPD on the wire from the battery to the starter it will always fail. The conductor can handle the inrush of the cranking amps but a OCPD will do its job.
Refer to the national electric code NFP 70.
Refer to this link for wire size:
http://www.alternatorparts.com/wire_size_chart.htm
