Hooker Header Alignment sleeves? Anyone use them?
http://www.jegs.com/p/Hooker-Headers...63776/10002/-1
I was just curious if anyone has actually used them before. Any tips or tricks to them, or are they as simple as running a tig torch over them to melt the filler/sleeve?
http://blogs.popularhotrodding.com/6...ers/index.html
Anyways what do you guys think, at the very least i hope i helped someone find a way to make their headers easier.
But if your fit-ups look like the ones in the picture above - don't bother - it is going to look buggered together anyway. It looks to me like he's trying to get a decreased radius bend by piecing it together with cuts that are not normal to the tanget of the bend
The rings are very thin with an upset in the middle that provides filler for the puddle. If there is any gap you will burn through the ring in a heartbeat
I found that even with a good fitup, I still get a little thinning at the weld joint and want to add just a little filler and you can grind them if you really want it to look nice.
Backpurge if you can too
Im using the jegs pre-bent inframe kit. I just need to shorten a few places, lengthen a few, and make room for my steering linkage.
Any easy way to back purge with a single tank/regulator setup? I don't have the spare $$$ for a second tank or dual regulator.
get a Y connector for the reg U do have. Allows for 2 hoses to hook to 1 tank. No flow report w/o the reg, but could be a trial/error type set up...
-https://ls1tech.com/forums/tools-fabrication/1144126-first-time-header-builder-some-helpfull-hints.html
^that lil clamp thing is dope.
