going to the dark side *engine is in*
Old Jul 14, 2011 | 12:25 AM
MattSapp95_T/A's Avatar
Originally Posted by bizerk1
is an lq4 a GTO engine... the 6.0 ?, where do u find the ones u guys get?
No the 6.0 iron motors are out of the trucks....Escalades and silverados mostly
Old Jul 14, 2011 | 12:28 AM
93Z2871805's Avatar
Veteran: Air Force
Originally Posted by MattSapp95_T/A
Kenny you know I can't help myself on the LT to LS threads
I know buddy, we'll get you the help you need soon...WHEN YOU FIRE THAT BEAST UP!
(By the way I reserve exclusive video on that event....)
OP his work of art runs a pretty penny, but he did his research and he's got a good combo coming together. He pointed me in the right direction on alot of my parts.
Old Jul 14, 2011 | 12:29 AM
Originally Posted by 97badass
im not sure the year? is there a difference? and yeah i know the merv he has been around a while.
mod list for it is a cam, ms3? timing set, ls3 heads (eventually but for now my stock 98 ls1 heads), ls6 intake, 90 tb, and bolt ons.
Cam - Call Geoff at EPS
Timing set - LS2 chain
LS3 heads will need - LS3 intake, Rockers, pedestals, head gaskets, intake etc pretty easy to piece together a little at a time
90tb - Nick Williams is nice
Bolt ons - go ahead and get 1 7/8 headers they will be a nice gain with the LS3 heads eventually.... keep stock rockers.... Underdrive pulley and call it a day... EWP if you don't mind spending 600 for 5-10 hp
Old Jul 14, 2011 | 12:31 AM
93Z2871805's Avatar
Veteran: Air Force
Like Matt said.
Call up your local junkyard for an iron 6.0.
Both mine and Matt's motors are 364 casting number blocks. Same with Merv.
Old Jul 14, 2011 | 12:33 AM
Well if the good lord willing and the creek don't rise we shall smell smoke in 2 weeks..... I will be sure to send you the and Ben the video as soon as it fires so yall can check it out...
Yea my build has gotten a little out of hand (started out as a 6.0 cam only LOL)
Thanks Kenny I try and help out when I can!!!
93Z2871805's Avatar
Veteran: Air Force
I minded, I picked up an OEM f-body one with 5k on it for like $50...
EWP will come when I go 427.
Old Jul 14, 2011 | 12:35 AM
93Z2871805's Avatar
Veteran: Air Force
I do appreciate it bud!
Old Jul 14, 2011 | 12:36 AM
Eh I am guilty....lol
Old Jul 14, 2011 | 12:38 AM
93Z2871805's Avatar
Veteran: Air Force
Every last drop of power- this guy will dig for it!
Old Jul 14, 2011 | 12:45 AM
the_merv's Avatar
LS1's suck...
Matt your car's a heap and Kenny you need to scrap that pile...
Old Jul 14, 2011 | 12:48 AM
93Z2871805's Avatar
Veteran: Air Force
And here he is...
I scrap mine when you bring grandpa's car back...
Old Jul 14, 2011 | 12:52 AM
  #32
the_merv's Avatar
Hey...that's a Monte Carlo SS, not a Cadillac douche..
Old Jul 14, 2011 | 01:00 AM
  #33
93Z2871805's Avatar
Veteran: Air Force
It originally came with the same 305 that was in my grandpa's caprice....
Come on seriously, who let Ben near the keyboard again...
Old Jul 14, 2011 | 01:15 AM
  #34
bizerk1's Avatar
Then the Gto would be LS2?, what is the differnce just that it is iron?
Old Jul 14, 2011 | 01:29 AM
  #35
93Z2871805's Avatar
Veteran: Air Force
GTO 6.0 LS2 Gen IV 58X, 243 heads (iirc), different front cover for front mount cam position sensor, different timing set, floating pins, same compression as an LQ9.
LQ4 Gen III 24X, has dished pistons, 317 heads.
GTO also came with a 5.7 LS1 just like the f-bodies.
LS2s are in:
Corvette
GTO
Trailblazer SS
Saab 9-7x Aero
Old Jul 14, 2011 | 04:23 AM
  #36
the_merv's Avatar
LS2 is an Aluminum Block..Knock Sensors are on the side of the Block.
Also they are a 24x Reluctor, except for the Vette in 2006.
Reference: https://ls1tech.com/forums/generatio...24x-wheel.html
Postin that reg up for you military types..
I'm here to educate you, per above info..
Old Jul 14, 2011 | 06:13 AM
  #37
97badass's Avatar
wow, this thread grew overnight! so since i will be going to obd2 from obd1 the car is a 95, just about the whole harness has to be replaced? any idea where to pick up a stock ls1 k member?
Old Jul 14, 2011 | 06:21 AM
  #38
97badass's Avatar
the heads are centerbolt, and matt your car is nasty looking. how hard is it to keep the a/c in this swap? and what kind of numbers will i put down with the mods you listed above?
Old Jul 14, 2011 | 07:24 AM
  #39
Yes centerbolt.... Buy a ls1 car harness and send it to Merv and he can make it plug and play for you along with A/C...... you can find ls1 k members pretty cheap in the classifieds on here... Especially from guys that went tubular....
Thanks I put a ton of work into it so it would be nice...
As for power....6.0 cam only and bolt on 400+ to the back tires through a m6
6.0 with ls3 heads and custom cam with all the bolt ons 475+ through a m6.....figure ls3 motors are making over 500 to the wheels cam and bolt ons only....
Old Jul 14, 2011 | 07:26 AM
  #40
Love you too Merv ....lol
