going to the dark side *engine is in*
Old Aug 9, 2011 | 06:00 PM
  #221
93Z2871805's Avatar
Veteran: Air Force
Originally Posted by 97badass
i just dont want a tb thats bigger than the intake manifold... i found a great deal on the alt, water pump, tensioner and ac compressor so im getting that stuff tomorrow as well as the oil pan and wiring harness. maybe merv can teach me how to do the wiring harness instead of charging me to do it.
After some research, I found out that the factory LS3 intake TB opening is 96mm. So that PP TB would be an exact match.
Old Aug 9, 2011 | 06:37 PM
  #222
97badass's Avatar
yeah its a big sob! i can fit my fist inside it, is there an easy way to make sure the cam bearings go in lined up with the oiler holes?
Old Aug 9, 2011 | 09:42 PM
  #223
the_merv's Avatar
Veteran: Air Force
The builder at the Machine Shop after he Hones it and Vats it..
Old Aug 9, 2011 | 10:42 PM
  #224
97badass's Avatar
thats an extra $200... by time i buy new rings, have it vatted, honed, and then him put in the bearings... ive got the tool at work took me 30 minutes to knock them out. cant be hard to install new ones. and i dont want anymore engine parts scattered out in my little work area.
Old Aug 9, 2011 | 10:44 PM
  #225
97badass's Avatar
**** it, do it once do it right... i will start tearing it down all the way and remove my head studs and take it in.
Old Aug 10, 2011 | 01:00 AM
  #226
the_merv's Avatar
Veteran: Air Force
There ya go..get a fresh engine..
Old Aug 10, 2011 | 12:16 PM
  #227
97badass's Avatar
rods and pistons slid out nicely, little bit of blood shed, now time for the crankshaft to come out, so far all the bearings look excellent besides the cam bearings with smearing on them??? rough to the touch with tiny ***** of metal on them
Old Aug 10, 2011 | 04:55 PM
  #228
1961ba427's Avatar
Originally Posted by License2Ill
Im thinking about LQ series...with recommended heads...and maybe even just keeping my trans and rebuilding it using the LS1 input shaft which I heard is all thats needed well outside of the bellhousing and slave assemblies.
you also need the front cover from an ls1 t56
I just had an idea hit me that seems so simple that there must be some reason it won't work or surely someone else would have mentioned it:
What about just using a 1999 (?) crankshaft that had the longer length giving the same distance from the block face to the crank flange as the traditional chevrolet v8's??
Could I just use my LT1 t56 with the stock bellhousing, clutch, flywheel, hydraulics, etc.???
Either this is a great idea or I'm about to get shot down with a reason why.
Old Aug 10, 2011 | 06:15 PM
  #229
93Z2871805's Avatar
Veteran: Air Force
Hmm....? I'm looking at a picture of both cranks side by side, I wonder if the older truck ones were .400in thicker to make up for that clearance?
Anyone know for sure? I think it's worth looking into.
I think merv mentioned something about this while talking to me about building a 4l80e.
Old Aug 10, 2011 | 06:28 PM
  #230
97badass's Avatar
finished tearing the engine down, pistons soaking in solvent, bearings marked for reference, noticed one bearing half on crank was starting to wear, number 5 cam bearing was trashed!
Old Aug 10, 2011 | 06:33 PM
  #231
97badass's Avatar
im gonna go back tonight and hit the pistons with the wire wheel to clean them up real good. put mains on block torque down and deliver to machine shop tomorrow and hope its done monday evening so i can stab the cam and get stuff put back together.
merv: whats the threads on the ps hole i have to drill/tap
Old Aug 10, 2011 | 06:45 PM
  #232
1961ba427's Avatar
What is it with LS engines and cam bearings/camshafts? I hear that alot of truck engines had camshafts replaced under warranty. There is a 4.8L in our shop that was replaced under warranty because of oil pressure issues. They tried alot of stuff to fix it before GM said replace the engine. I'd have to pay $300 for it....which seems alot for a 4.8 with issues (good used ones are under $500 usually) but I know it has a new set of LS7 lifters in it along with alot of other new parts.
Don't forget to inspect/clean the ring lands. They make a tool for it, but an old ring works pretty good too. I usually break one in half so it's easier to manage.
I've also heard alot about oil pump issues...ported stock oil pumps....LS6 oil pumps....etc, but I didn't file it to memory because I didn't have an LS engine at the time. Is this a problem area all of us LT1 guys doing the swap need to look into?
Also.....I don't think I would wire wheel the piston skirts if I were you. Maybe it wouldn't hurt anything, but when you are only talking a few thousandths piston to wall clearance, I wouldn't want to do anything to wear any off the skirts. I haven't looked at late model pistons, but I know most older stuff have little tiny ridges that help with oil control.
Old Aug 10, 2011 | 06:52 PM
  #233
1961ba427's Avatar
That is what I've always read. The longer cranks to accomodate the 4L80e. I've heard it was only 99 models, but then other places said 99 to 2001's. I will try to find out at work tomorrow. Maybe a call to GM Partech would help, but they can be unwilling to help without a VIN number. They don't want to talk anything about conversions or using a part outside of it's GM original application either. I understand their reasons, but it's a shame too considering the amount of information they have available to them.
Old Aug 10, 2011 | 06:53 PM
  #234
the_merv's Avatar
Veteran: Air Force
Its been tried with the LT1 T56..doesnt work..flywheel's dont work, different bolt pattern..then you have to figure out the Slave setup you want..all kinds of issues.
M10x1.5mm, it's for the Alternator, not the Power Steering.
Old Aug 10, 2011 | 07:03 PM
  #235
1961ba427's Avatar
I didn't realize the flywheels had a different bolt pattern. You are talking about the flywheel to crankshaft bolt pattern right?
Old Aug 10, 2011 | 07:54 PM
  #236
gofastwclass's Avatar
Yes. Completely different bolt pattern.
Even still, you end up with a mess of clutch / throwout bearing issues. Not saying it can't be done, but it isn't practical. Best thing to do is find a Gen III T-56 and sell the Gen II to someone who can use it. Jason @ TDP (sponsor) sells them rebuilt outright for a reasonable price. I'll probably go with him on my next one.
Old Aug 10, 2011 | 08:05 PM
  #237
97badass's Avatar
same difference, lol... i know about the ring lands... we have the tool for it
Old Aug 10, 2011 | 09:19 PM
  #238
97badass's Avatar
just found some heads!!! woohoo
Old Aug 10, 2011 | 10:12 PM
  #239
the_merv's Avatar
Veteran: Air Force
You post up here like this is twitter or some ****..lol..
Old Aug 10, 2011 | 10:54 PM
  #240
97badass's Avatar
gotta keep it updated! lmao. but i scored a hell of a deal on the heads
