First test fit of LS1 & T56!!!!
I'll attach one pic. More can be found at http://matt.undiagnosed.org/images/vette/LS1/ Warning... most of those pics are 1280x960x200dpi so dialup beware.
Thanks for everyone's help. Things are finally starting to look like they're progressing.
-Matt
Looks good, I seem to be going backwards on mine again.
Yeah I did. Haven't had much of a chance to get back to you. When I had made my engine mounts, I decided to move the engine forward a few inches. Not a lot, just enough to clear up some issues. So on mine, the two mounting holes in the bottom of the tranny just happened to be in front of the crossmember. I had a mount welded to the frame then used a rubber mount for an auto. The holes lined right up with the trans. I used a spacer (nuts) to raise the mount up a little and it fits great. I can crawl under there and take a pic if you would like.
