turbo 5.3 s10 build
Old 05-10-2012, 08:04 PM
  #201
Sarg's Avatar
Guess you are going to have it narrowed?
Old 05-11-2012, 03:58 PM
  #202
T76s10's Avatar
Me to man i'm itching to Get it going but i'm super short of money so it's taking a long time. Hoping to run 10's once it's around 15lbs boost. No sarg i'm just going to drop it in how it is even though the drive shaft will be offset. I heard that you can fit a 10" rim with 7.5" backspacing and a 315 tire without narrowing it.
Got the 8.8 ripped apart today and painted. I need to get my limited slip center section to put in with my 3.27's still though and I need calipers, rotors, and brakes.
Old 05-13-2012, 10:20 AM
  #203
Tuckin15s's Avatar
Looking good man! How much total do you have in the turbo and all the piping?
Old 05-13-2012, 08:22 PM
  #204
T76s10's Avatar
Turbo - $350
bow off vale - $150
wastegate - $190
hotside Piping - $350
Intercooler - $120
Intercooler piping - $200
I think that's all the turbo related parts. But then I have the wideband, boost gauge, oil pump, oil lines and all that other good stuff that works with the turbo haha
Got the old piece of **** 7.5" rear out and placed my 8.8 on place. The u bolts ended up being the wrong size so I Gotta go to napa to get the right ones so I can bolt the Bitch in.
Got my motor grounded and tried starting it again today. I'm getting spark but no injector pulse. I think it's because my ignition wire shuts off when the engine cranks so it shuts the ecm off so I have to re wire that. Then it should start
Those mother ******* sent be blue couplers. They came from China so no way in hell am I going to send them back. they took two Weeks to get here
Old 05-15-2012, 04:33 PM
  #205
468BIGBLOCK's Avatar
Default lookin good!!
i like it!!
Old 05-15-2012, 05:32 PM
  #206
Sarg's Avatar
Looking good...the bed mounted turbo is interesting, lol.
Old 05-15-2012, 05:35 PM
  #207
T76s10's Avatar
Thanks! Lol I know sarge that's why I decided to do it. I didn't want a rear mounted turbo underneath like the sts kits so I decided to copy carshops turbo s10 but I like the way mine ended up much more than theirs.
Old 05-15-2012, 05:37 PM
  #208
Freeman83's Avatar
subscribed! great build man
Old 05-15-2012, 08:37 PM
  #209
T76s10's Avatar
thanks! i just got it started literally a couple minutes ago. it runs like hell but still needs to be tuned and its smoking like crazy from the paint on the headers and i have a few leaks. i been checking out your build thread on your first gen s10, wish i was able to move that fast haha. where you plan on placing your turbos?
Old 05-15-2012, 10:11 PM
  #210
Freeman83's Avatar
**** im 2 1/2 years into my build, those are old pics so far lol. Its taken a while. Im just picky and patient. Im putting them on either side of the motor, very tight but it will work out nice.
Old 05-16-2012, 05:00 PM
  #211
T76s10's Avatar
Haha that explains why out looks like your hauling. I wish I could have fit a front mount but oh well. Good luck fitting your twins, it was super tight for me with truck manifolds but your engine is back father so I think you'll be good
Old 05-16-2012, 06:33 PM
  #212
Freeman83's Avatar
thanks man, im planning on using 98-99 camaro manifolds....if i can find them. Im kinda at a stand still until i do. yeah there isnt much room up front in these trucks.
Any updates on this?
Old 05-19-2012, 04:01 PM
  #213
T76s10's Avatar
Yeah I got a few still gotta take some pictures when I get home
Old 05-20-2012, 07:43 PM
  #214
T76s10's Avatar
decided to mount the hp tuners in the car so i dont have to take it in and out and so the lines are routed inside the cab
got the rear end bolted into place. just have to put the gears and axles in and finish the brakes
also finished my intercooler piping
and heres my oil pump for the return line. im using 1/2" hose (-8an). that one hose is hanging down because i havent zip tied it into place yet
and heres where it goes back into the oil pan
Old 05-22-2012, 08:24 PM
  #215
T76s10's Avatar
Here's a video of the truck starting
Old 05-22-2012, 09:22 PM
  #216
Freeman83's Avatar
Looking good man. I cant wait to see the wheel fitment. Im going to be running the same rear end and im curious how that will turn out.
Old 05-22-2012, 10:54 PM
  #217
T76s10's Avatar
You going to drop yours 3" also? Your going to have to have like an 8.5" backspace to tuck the wheels under the wells I think since you have a first gen. Second Gens have the fender flares so I have to run 7.5" backspace with a 295 tire. I won't have my drag wheels fire a while though so I have to poor some shitty wheels on for now
Old 05-23-2012, 06:55 AM
  #218
Freeman83's Avatar
Oh ok, I guess once I have the rear end on I'll have to do some measuring to figure out the back spacing. I'm lowering it 4" in the front I believe. the rear is getting a 4 link and coilovers.
Old 05-23-2012, 08:33 AM
  #219
T76s10's Avatar
yeah im not positive though but that would probably be your best bet. if your doing a 4 link with coils might as well throw a full tub in
Old 05-23-2012, 09:43 AM
  #220
Freeman83's Avatar
Lol, I thought about it but I think ill hook fine without the monster tires. Im excited to see what yours does on the track. Any plans for that in the near future?
Quick Reply: turbo 5.3 s10 build
