Small radiator? 404ci overheating.
I don't have a true 50/50 coolant mix, and i have one 14" electric fan on my radiator.
Here you can get an idea of the size of the radiator.http://www.youtube.com/watch?v=xyabd...er_profilepage
I plan to add a pusher fan and some more undeluted coolant to bring the mix closer to 50/50.
Anyone else come across this problem with a small radiator?
Can see from the vid.. can't see what Fan setup you have !? Might also check for a Lean condition, vacumn leak.
T stat is def opening.
Did you simply take off the hose and add more fluid, or drain and refill.
Going to research the best way to clear to system of air now.
I was going to get another fan and use it as a pusher till i get time to make a shroud.
Im starting to get convinced its air in the system. Im going to try and blead it tomorrow and she what happeneds. If it fixes it i'll hold off on the pusher fan.
www.spalusa.com pick out the biggest highest cfm fan or fans that fit your radiator. Build a schroud and pick up a spal fan controller.
You could have a air bubble I set my stuff up so the highest point in the engine is the steam crossover in the front of the motor and put hose to the radiator tank.
Tim
if it really was the 5 min mark or so that is FAST - like air bubble fast - because no motor is going to heat up that fast idling
The builder is very reputable, but i will pull the heads if i cant find the solution.
Yes its actual at the 5min mark that my small overflow started spiting out fluid everywhere. Im going to pull the upper hose and see if i can fill it from there. If it still overheats ill drain and start over. Also i dont have the vent tube in the correct place. Its going to a t in the heater core loop. Dont know where i got that idea but it will yet fixed as well.
When you put your hand on the radiator core, is it hot? Is the whole thing hot, or just the top, or just the bottom?
Does the overflow bottle need to be higher than the radiator cap?
Does it overheat at idle or just when you're driving it?
I second the idea for the fan shroud... though I'm not sure that's the problem.
The core is definitely hot on top. never though to check the bottom.
I have my below the cap. If you see the video its the bottle to the left of the radiator. It was a temporary solution till i find something that fits properly or i make on.
Just during idle. My tranny is out since its jammed and i wanted to run the motor a little and sort out bugs like this while i work on getting the tranny fixed.
It will get a shroud evetually, for now i'll pick up a stronger fan[aka spal], and i'll make a shroud when i get a chance. Maybe a good winter project.
As the temp rose i found that only the top of the radiator is getting hot.
I also notice that my heater hose tube was kinked, so i don't think it was flowing very well. Would that cause it?
Definitely need a good fan to keep the motor cool at idle. I have an adjustable fan and can pretty much put the idle temp anywhere I want it. Getting a shroud that pulls air through a larger radiator area will help.
Pure water does cool better than a 50/50 mix, but the aluminum needs antifreeze to keep it from corroding while the water pump needs the glycol for lubrication. Don't run pure water and don't run more than 50% antifreeze.
These motors do need at least a quart sized overflow. The water will expand even with an air bubble.
My guess is once you get all the air out it will stop overheating. the fact only the top of the radiator is getting hot shows the radiator is cooling. Just keep topping it off and eventually it will shed the air.
The other thing is my car was sucking water out of the overflow bottle even after a few warmup cooldown cycles. So warm it up to 215 or so, then let it cool and make sure your overflow tube is in adequate fluid. Repeat this a few times and see if it draws in fluid. Basically the steam will escape and then the vacuum created while cooling down wil suck the fluid back in from the overflow.
Do you have a steam vent back to the radiator? Its advised. But if you insist on not having one, at least vent the port while filling the engine or vent it while hot to vent any steam(be careful if you do it this way).
Keep us up to date.
if you look at the coolant flow path, you'll see what I mean, the only hot coolant flowing past the thermostat comes from that heater hose return, so if it is kinked, I bet that is your problem.
I found it almost impossible to get all the air out upon filling the system on my engine, I ended up drilling a couple 1/8" hole in the perimeter of the thermostat, which made it easy to fill the engine/cooling system without air lock
