Finished 474hp LS2 G35
Old 10-04-2011, 05:14 PM
Fafonfoe's Avatar
Default LS2 Stroker Infiniti G35 Full Bolt Ons
Well I have had a few people wanting me to post about the complete build so here goes. 04 G35 Coupe with LS2/ T-56. Mods LS6 Heads Stage 2.5 , 231/236 112 Cam, 1 7/8 LT Headers, Borla Xr-1 with 3" back. Ported TB, Custom Intake, Billet Flywheel, monster stage 2 clutch, wilwood clutch master, LSX conversion dual pass Rad, Walbro 255, Fast 42 lbs injectors. http://www.flickr.com/photos/52712020@N02/5989921226/ http://www.flickr.com/photos/52712020@N02/5989921226/ by http://www.flickr.com/people/52712020@N02/, on Flickr http://www.flickr.com/photos/52712020@N02/6082676585/ http://www.flickr.com/photos/52712020@N02/6082676585/ by http://www.flickr.com/people/52712020@N02/, on Flickr http://www.flickr.com/photos/52712020@N02/6083216640/ http://www.flickr.com/photos/52712020@N02/6083216640/ by http://www.flickr.com/people/52712020@N02/, on Flickr http://www.flickr.com/photos/52712020@N02/6083216170/ http://www.flickr.com/photos/52712020@N02/6083216170/ by http://www.flickr.com/people/52712020@N02/, on Flickr http://www.flickr.com/photos/52712020@N02/5989921762/ http://www.flickr.com/photos/52712020@N02/5989921762/ by http://www.flickr.com/people/52712020@N02/, on Flickr http://www.flickr.com/photos/52712020@N02/6052215664/ http://www.flickr.com/photos/52712020@N02/6052215664/ by http://www.flickr.com/people/52712020@N02/, on Flickr http://www.flickr.com/photos/52712020@N02/5989362297/ http://www.flickr.com/photos/52712020@N02/5989362297/ by http://www.flickr.com/people/52712020@N02/, on Flickr http://www.flickr.com/photos/52712020@N02/5989362073/ http://www.flickr.com/photos/52712020@N02/5989362073/ by http://www.flickr.com/people/52712020@N02/, on Flickr http://www.flickr.com/photos/52712020@N02/6212015163/ http://www.flickr.com/photos/52712020@N02/6212015163/ by http://www.flickr.com/people/52712020@N02/, on Flickr New wheels from saleen mustang 18x10 rear 18x9 front so I can get some tires on it and traction. http://www.flickr.com/photos/52712020@N02/6212527870/ http://www.flickr.com/photos/52712020@N02/6212527870/ by http://www.flickr.com/people/52712020@N02/, on Flickr http://www.flickr.com/photos/52712020@N02/6212011591/ http://www.flickr.com/photos/52712020@N02/6212011591/ by http://www.flickr.com/people/52712020@N02/, on Flickr http://www.flickr.com/photos/52712020@N02/6212520818/ http://www.flickr.com/photos/52712020@N02/6212520818/ by http://www.flickr.com/people/52712020@N02/, on Flickr http://www.flickr.com/photos/52712020@N02/6212517886/ http://www.flickr.com/photos/52712020@N02/6212517886/ by http://www.flickr.com/people/52712020@N02/, on Flickr http://www.flickr.com/photos/52712020@N02/6212514470/ http://www.flickr.com/photos/52712020@N02/6212514470/ by http://www.flickr.com/people/52712020@N02/, on Flickr http://www.flickr.com/photos/52712020@N02/6211997711/ http://www.flickr.com/photos/52712020@N02/6211997711/ by http://www.flickr.com/people/52712020@N02/, on Flickr http://www.flickr.com/photos/52712020@N02/6211993743/ http://www.flickr.com/photos/52712020@N02/6211993743/ by http://www.flickr.com/people/52712020@N02/, on Flickr http://www.flickr.com/photos/52712020@N02/6211991455/ http://www.flickr.com/photos/52712020@N02/6211991455/ by http://www.flickr.com/people/52712020@N02/, on Flickr http://www.flickr.cN02/6211986845/ http://www.flickr.com/photos/52712020@N02/6211986845/ by http://www.flickr.com/people/52712020@N02/, on Flickr Car tuned by Thunder, Dyno 474 RWHP 430 Torq. SAE. Next upgrades.... MT tire in the rear, pulling motor out this winter and will probly change the complete setup. Want more power. All that had to be changed . Computer ( Vats Delete ) Custom wiring harness both G35 and LS2. Custom Master Cylinder, Custom drive shaft, custom long tube headers kit upraded LSX rad dual pass, Oil Pan (7 quart dual trap )Custom intake, dual fan relays, custom shifter kit it G35.
Old 10-04-2011, 05:46 PM
Tainted's Avatar
whats the lift on your cam? Oh and how much did sikky charge for the wiring harness work? What radiator exactly?
Any other unexpected problems? I know you had to run the aftermarket tach, any chance theres one that can fit in the factory bezel?
Saving this thread Gonna need it in a month or so
Old 10-04-2011, 07:05 PM
Fafonfoe's Avatar
231/236 112 cam . The rad is from summit it's a lsx dual pass rad. It's the only one that can keep the temp down allthe time. Sikky charges 550 for the harness. I would use chase bays harness. I had to rework some of my harness after I got it back. Some of the issues were heat sat. On the starter from lt headers. The heating issue that the rad fixed, went through three rads. 3". Exhuast was hard to run nice all the way back but thanks to a local shop he did it perfect. Had to use a tach adapter and no I couldn't fit any kind of gauge in the cluster. I tried four different kind and sizes. Let me know if you have any issues or need help with your build. Also run heat cover on clutch line and go 4an. Last make sure your do the drill mod.
Old 10-04-2011, 07:20 PM
Tainted's Avatar
Much thanks for all the guidance! I wish someone could figure out a nice tach that's somewhat hidden! I know your cam was a 231/236 but do you remeber the intake and exhaust lift? How's the low end power with that cam? Highly considering have pat G custom spec me a cam. Oh and did you ever get that car weighed??
Old 10-04-2011, 08:37 PM
boriksh's Avatar
very nice build. any videos? i want to hear how your cam sounds.
Old 10-04-2011, 09:28 PM
Fafonfoe's Avatar
http://www.youtube.com/watch?v=pCRj2RWxsoM
http://www.youtube.com/watch?v=oBGKO...eature=related
I have terrible gears. I shift out of 4th at 140 mph. Looking into getting better gears.
Old 10-04-2011, 10:04 PM
Tainted's Avatar
stock 3.54 LSD correct? Is the driveability still good though? its hard to read the dyno graph to see how much low end you have
Old 10-04-2011, 11:06 PM
11 Second Truck Club
bluecajun5.3's Avatar
seen it at the track a few weeks ago in the pits. what did it end up running?
Old 10-05-2011, 06:45 AM
Fafonfoe's Avatar
Yeah its 3.54 gears. It drives perfect. It has great power through out.
Yeah when I was at the track first pass I spun all the way to fourth. Damn street tires. Next run we launched in secound gear and ran 13.01 @ 128 MPH/ .493 RT. Don't remember 60' but wasnt very good.
Still spun a little in 2nd. I ordered mustang saleen rims 10 wide and will put some MT tires and go back. Looking for 11 flat if I dont rip the rear end out or kill driveshaft.
Old 10-05-2011, 07:04 AM
2nd Gen Fl 'bird's Avatar
Always loved the G35 but, with the LS platform? It does not get any better for a conversion. Love it!
Old 10-05-2011, 08:01 AM
Regulator's Avatar
If you don't mind me asking, roughly how much did you have tied up in the conversion when it's all said and done? My next car is going to be a G35 and I would love to do something like this down the road.
Old 10-05-2011, 08:58 AM
makdaddynuge's Avatar
nice build. Love a red g35. I am about to get this same swap underway for my 350z. The only thing that is scarying me is the wiring. I have heard the sikky wiring is not all that great, and wiring to me is like a whole different language. Any complaints about your wiring? I wonder if chase bays is making better progress because i have yet to see a g35/350z with ls1 and chase bays wiring
Old 10-05-2011, 09:05 AM
Fafonfoe's Avatar
04 g35 sport 10900
Ls2. T56. 4500
Heads cam clutch flywheel intake 3200
Exhaust 600
Gauges. 400
Sikky kit 4700
Rad lsx dual pass 180
Misc ( fuel pump ,lines) 220
I have had problems with sikky harness and a few others I've talked to. Evap delete, check engine light. I've talked to Logan at chase bays and they sound like good people. Don't know about their work but from what I've seen and heard they are very good and the harness looks great that they do. If anyone has any problems with their build ask me any questions. Ive been through every problem imaginable with this build. Very happy with the results.
Old 10-05-2011, 09:14 AM
Fafonfoe's Avatar
Also 650 for tune
Al together about 25k
Old 10-05-2011, 09:17 AM
boriksh's Avatar
sweet g35, on the first video it almost looks like the sound coming from truck next to it.
Old 10-05-2011, 10:11 AM
Are you still running the stock final drive gear (3.5)? How does that feel? Do you feel the 4.08 fd would be too short? I am pretty most poeple on this forum with fbodys an vettes like to go 4.10 and higher.
Old 10-05-2011, 10:24 AM
boriksh's Avatar
I love my 3.23 with my ls2 t56 in a bmw, feels not too short and not too long.
Old 10-05-2011, 10:42 AM
Tainted's Avatar
Originally Posted by Fafonfoe
04 g35 sport 10900
Ls2. T56. 4500
Exhaust 600
Gauges. 400
Sikky kit 4700
damn, where did you find an ls2 dropout for $4500??? Im looking in the midwest and cant find anything better than about $6,000 for ls2 & t-56 with 50k+ miles
Old 10-05-2011, 11:02 AM
Fafonfoe's Avatar
It took a while but got a hook up from a friend at lkq. The gears seem great always have power no matter what gear
Old 10-05-2011, 11:53 AM
Regulator's Avatar
How many miles were on your G35 when you got it, 10,900 seems like a hell of a deal for one. Any idea why they aren't able to translate the signal to the stock tach? I mean it has to be possible somehow...
Quick Reply: Finished 474hp LS2 G35
