Goodbye 4-Banger, Hello LS2 – Miata Build
Old 01-16-2012, 02:04 PM
  #101
MX6.0's Avatar
I took some time today to de-power the power steering rack the right way. For years I had been running with the hydraulic lines looped together. This worked fine but I figured while I had the car apart I'd remove the seals from inside the rack and plug up all of the fittings.
The first pic is of the seal that needed to be cut from the rack.
The last 3 pics show the fittings that were plugged. Since there is no longer any hydraulic pressure inside the rack, the main purpose of the fittings is to keep dirt out and grease in.
Old 01-22-2012, 08:11 PM
  #102
MX6.0's Avatar
I mounted the engine/subframe back in the car to finish test fitting things.
The first thing I did was work on the radiator mounts. I unbolted them and moved it forward so the rear mounting hole was now bolted to the front hole. Then installed the radiator with just the 1 bolt holding it in. Leaving only 1 bolt holding it allowed me to rotate the mount to get the front of the radiator to the right height. Once I got the radiator where I wanted it I removed it carefully without moving the mounts from their position. I then welded the front of the mount in place and tightened the rear bolt.
Here's a shot of the clearance between the radiator and the front support. After some modification to the OEM top radiator bracket I was able to bolt it in using the stock rubber bushings.
Now that the radiator was done I started on the sway bar. After holding it up in place I noticed that it was only about 1/4" too far back to clear the front of the pulleys. If I could move the mounting points of the sway bar 1/2" forward I could keep my 1.125" swaybar. I used a 1.5" x 4" piece of 1/8" steel plate and welded it to the existing swaybar mount. This would allow me to drill new holes 1/2" forward of the existing holes without weakening the mount.
Here it is all bolted in place. Plenty of space left to get the belt on and off.
Old 01-22-2012, 10:19 PM
  #103
bryan23's Avatar
your swap is coming together very nice, are you going to make that rear end stronger to handle all that power?
Old 01-23-2012, 05:52 AM
  #104
68 TT's Avatar
Great project. I have wanted to do this swap to my mom's Miata since I bought my 98 Z/28 when it was new.
Thanks for sharing all the parts & costs involved in the process. Keep up the great work.
Old 01-23-2012, 06:01 AM
  #105
RyanEricW's Avatar
real motor in a wanna be sports car, gg
Old 01-23-2012, 06:19 AM
  #106
MX6.0's Avatar
Thanks for the awesome input... Very informative. Sounds like you really know you're sports cars. Seriously though, it's not like the thread topic was misleading. If you don't like the car why even bother looking? Just to be a dick?
Old 01-23-2012, 06:26 AM
  #107
MX6.0's Avatar
I'm using a 3.23 CTS rear. https://ls1tech.com/forums/15498606-post10.html
Old 01-23-2012, 08:20 AM
  #108
LS1-450's Avatar
http://i974.photobucket.com/albums/a...s/P1010436.jpg
2 for 1, lol. By welding the plate to the bottom of the anti sway bar bracket, you reinforced the area on the bracket that fails. The 90* bends where you welded the plate on are where they fatigue & then begin to "sway" side to side. The weld strengthened the area. Would still suggest putting rectangular tubing inside the bracket large enough to touch side to side & top to bottom & tack weld next to where the stock brackets bolt to the frame (bolts can snap).
Looks great. You were able to install the bottom of the radiator & anti sway bar much higher than most. Well done.
Old 01-26-2012, 08:54 PM
  #109
MX6.0's Avatar
Finally finished welding everything in the engine bay and behind the dash.
I had some clearance issues with the top of the bell housing and the firewall. From the 90* angle, I made a 1" cut up and another 1" cut back and then folded the top and bottom pieces together. Then I used some 16 gauge steel and made some small triangle pieces to fill in the sides. The top is 3" wide, the bottom is 4" wide. I think it turned out pretty nice and it should give me plenty of clearance.
Old 01-26-2012, 09:13 PM
  #110
violent_celerity's Avatar
A miata is more of a sports car than an F-body.. It actually turns in its stock form.
Awesome thread. The service manager at my shop is a huge miata nut, I keep showing this thread to him to hopefully inspire a cool swap into his 1992.
Old 01-26-2012, 09:17 PM
  #111
MX6.0's Avatar
Vacuumed all of the metal filings out of the interior and engine bay to start prepping for paint. I don't plan on doing the whole engine bay. Probably just the horizontal sections and the areas that were welded.
Here's an area that I might touch up. Although the car has spend 90% of the time in the garage, it's managed to get some surface rust in a few spots. Mazda was also pretty sloppy with the seam sealer.
I put seam sealer around the interior braces. Thank god I don't have to look at those welds anymore.
I also put seam sealer around these little holes behind the seats. There must have been $5 worth of change jammed in there.
Old 01-26-2012, 09:42 PM
  #112
salemetro's Avatar
No arguing with that. I enjoy my Fbody....it's a fun car for what it is...and some would say that it's "Highly modded". But I LOVE driving my Miata....it can be tossed around like nobody's business, and seems to be pretty damned predictable.
It's funny how all the ****-talkers love to voice a negative opinion about the Miata...just for the sake of being a blowhard. I work with a couple of guys like that. I got to hear all the BS about my Miata (Gay car, Ricebox, Chick's car...blah, blah, blah....) while mine was going together.
Funny thing happened though: One of the **** talkers took ONE ride with me once the car was done, and swore he'd never do it again...it was definitely priceless LOL
The other guy refuses to get in the car with me, and I get to tell him on a semi-regular basis what a ***** he is.
The best part; all the ****-talking has ceased.
If the Miata is a "wannabe" sportscar, then what in the hell is a "real" one??
Oh...wait...it's not a Mustang (chicks car) or a Corvette (but it handles like one and is faster(now) and lighter.). Hmmm....looks like I had better re-think this whole Miata thing....
And YES, I agree....awesome build thread!!
Old 01-28-2012, 04:38 PM
  #113
Brian68's Avatar
Predictable how asses like your stupid co-workers would rather knock your project because of jealousy than say something cool and buy gas for a couple of rides. Nice build.
Old 01-29-2012, 01:33 PM
  #114
MX6.0's Avatar
I'm working on painting everything up this weekend. Mazda went a little crazy with the seam sealer around the upper shock mounts so I cleaned them up a bit.
Here's a shot of one of them before I did anything.
Here it is after cleaning up the excessive seam sealer and smoothing things out a bit with new seam sealer.
And here it is after some fresh paint. I think it turned out 10 times better than it originally did.
Old 01-29-2012, 01:48 PM
  #115
MX6.0's Avatar
I added seam sealer to the areas where I removed the old sealer and to the areas where I wanted to smooth out (hide) my welds
Then I primed all the areas where bare metal and seam sealer were visible.
And here's the finished product. The spray can paint I got from Paintscratch.com seems like it's a pretty close match.
I used electrical blank-off plates to clover up the unused holes in the firewall. 2 for the old heater hoses, 2 for the old throttle cable and cruise control, and 1 for the hole I made for the additional turbo related wiring. I was originally looking for some sort of rubber grommet to put in there but I think these metal plates turned out better.
Old 01-29-2012, 05:12 PM
  #116
craigs73's Avatar
pretty neat project you have going here!!! should be a fun lil rocket to drive around! so how are you liking the lift after using it for awhile?
Old 01-29-2012, 05:34 PM
  #117
MynameisLee's Avatar
Wow, this is so cleanly done. great job
Old 01-30-2012, 12:01 PM
  #118
MX6.0's Avatar
The lift has more than paid for itself. I raise the car up so I can paint everything easier, it made welding underneath much easier, any work done under the car is made 10 times easier with the lift.
After test fitting the engine/transmission a hand full of times I couldn't imagine doing it without the lift.
Old 01-30-2012, 01:16 PM
  #119
boriksh's Avatar
wow this is such a fun project. having a lift in the garage adds a lot of convenience.
Old 01-30-2012, 03:57 PM
  #120
blk mk8's Avatar
i love the attention to detail and how clean everything is, it is coming along very very nice.
Quick Reply: Goodbye 4-Banger, Hello LS2 – Miata Build
