New conversion project, need all the help I can get
I've had a plan to convert this car to LS power and then, almost decided not to to keep it original. 2 weeks ago I was made an offer on the existing engine ( a 455) and took it. Now I have a non-running 18 foot long wagon taking up shop space.
I own an engine shop building performance and road race engines, so the actual engine part of the build I can do, and I'm not scared of electronics either, but what I don't have is time to do all the research I needed to do or a big budget to waste money of incompatible or incorrect parts..
My Questions are.. (Warning they may be dumb questions.)
1. Is there a computer that works with an LS3 (2010 camaro) TB, intake and 2004 6.0L? Which one should I be looking for?
2. do you need a 24x or 58x reluctor to use the LS3 TB and have cruise control?
3. Assuming I can put together a DBW system, what pedal do I need for the LS3 TB? Is there a TAC that I will need too?
4. what factory harness could I start with to make this all work in the end? I need to find a harness, the cheaper the better and I don't mind modifying a factory one if it saves me some money.
So here's what I have so far.
2004 LQ4 (It will be bored .030 w/ LQ9 pistons installed)
I have either 58x or 24x cranks in the shop.
LS3/L92 heads
LS3 throttlebody
~2001 corvette computer (not sure what P/N, just found it on a shelf)
Misc other LS stuff
I have more time than money, I have plenty of tools, CNC machiines etc. so anything I can build make or modify is more attractive to me than spending the money on aftermarket stuff.
thanks in advance
I've always preferred the Cable TB's, easier to work with IMO..everything I have has them in. There are plenty of guys here tho that setup DBW, so they can help. It's been done with the LS1 Vettes and they were 24X Factory, so Crankshaft isnt an issue.
I've had good luck using LS1 F-body Harnesses, then again it comes down to what PCM you end up running.
2010 ecu is 58x reluctor, 04 is 24x reluctor. You could use a 24x reluctor ecu with a 58x coverter but that's not cost effective.
The cruise conrol will work with either, but it's easier to get the 24x cruise to work.
Get the pedal, ecu, and TAC from the same vehicle, save yourself a headache. Earlier engines had a TAC, but I dont think anything past 07 has the TAC module.
Try to source the harness, ecu, tac, pedal, for the model/year of the engine.
From your list of parts, I would go with the 24x crank, LQ4 block, L92 heads, 01 ecu (411?). Then just source an aftermarket 4 bolt TB or conversion (speartech) TAC/pedal and pretty much any early DBW harness. I think PSI on here has a killer deal on the pedal/tac. And there's PSI......lol
That route might be easier than going with the 58x crank and sourcing a later, less common, and more expensive pedal/harness/ecu, but you could go either way.
1. If you are running a 24x setup, DBW is easy, just make sure the TAC, Pedal, TB and Tune match. This will be easier for cruise control as well as the 58x E38 controllers would require the use of the BCM.
2. If you are going 58x there is no TAC module. The E38 ecm will take care of the throttle functions and you will only need the correct pedal (we use new GM Corvette pedals).
3. If you decide to go DBC, go 24x as the E38 controller will not support the DBC.
4. LS3 throttle body will work with the 24x however, you will have to run the corvette tac module, pedal and tune. Corvette Tac and Pedals are expensive right now because GM is backordered (I have a feeling they are going to discontinue them).
As Merv said, your harness options are dependent on which crank/controller you decide to go with.
Jon
PSI
Your Source for LSX Conversion Parts!
www.psiconversion.com
Ebay Store
Facebook/psiconversion
Instagram/psiconversion
'Dont Let EFI Pass You By!'
I spend hours last night trying to learn as much as possible. I think I've come up with a basic list of parts I need to source.
From the looks of it and from what you guys have said, trying to use a later ECM is just not worth the effort or cost effective, so I think I have decided to do this:
24x crank
trade or sell my LS3 TB for an LS2 DBW TB (I checked and mine is the gold one)
convert the sensors on the block to LS2 style (knock and cam)
L92 heads
Hopefully the PCM I have is an acceptable one. I haven't looked at the numbers.
Unfortunately my idea of using an LS3 cam looks like it has no solution, but I may try and modify a 3 bolt sprocket to work. If I can't find a way to make a safe and quality fix to the problem, I'll hunt down a LS6 cam. LS3 cams are just so damn cheap
From what I have read so far, it is not that desirable a pcm to use. I haven't found out why yet....
I want to run DBW, 4L60E, LS2 style and location knock sensors and cam sensor. What year PCM and harness should I be looking for?
All F-bodies are DBC, and only late model trucks have DBW, what does that leave me with? LS1 corvette or late truck harness?
If it wont, and you want cruise control, you're probably better off looking for a 411 ecu, pedal, tac, harness package together.
Jon
PSI
Ebay Store
I know I should have bought a complete pullout, but this whole project started with leftovers at work: LQ4 block, new set of .030 pistons, LS3 heads etc. etc.
skip to 5:30. You'll thank me later.
http://www.youtube.com/watch?v=r3vqTcanU18
Has anyone had any experience buying a harness from this guy?
http://www.ebay.com/itm/97-07-LS1-DB...#ht_500wt_1413
http://techrods.com/index.htm
Then check with Speartech. They list adapters for an LS2 4 bolt TB, not sure if the LS3 is different.
Jon
PSI
Ebay Store
