69 Plymouth ls swap, what are my options for a gas tank?
Good evening folks,
I've gotten to the point in my build where I'm contemplating what I should do for a gas tank. Originally I wanted to go with a custom efi fuel tank but after quickly realizing that they are EXPENSIVE I've decided to look for alternatives.
My question is: since I will be using a corvette regulator/filter combo could I go with a 98-02 f-body gas tank and just have my fabricator build mounts for it to attach to the 69 plymouth body?
I was also thinking of a stock reproduction 69 plymouth fuel tank with an external surge tank. Since the reproduction tank will not be baffled and I wouldn't want starvation issues. Could this work?
If you guys have any comments on my ideas or any other economical ideas please let me know. Thanks.
Marvin
Marvin
I am using the stock tank in my Chevelle. It has a sump welded in and an external electric pump to feed the carb. When I switch to LS power gonna use Aeromotive A100 pump in place of the Holley Black pump.
Thanks for the idea. I thought of using a fuel cell that came with the car (also has a welded sump) but I thought I would run into starvation issues with the cell anything less than full (because of no baffles). Any thoughts?
On the stock tank with sump welded on, you only cut 3 or 4 holes with a 1 inch hole saw in the bottom of the tank... That makes a baffle in its design.
Hey LS1Ace, here is some tech.
You can a new tank with an in-take pump setup for the Valiant from Rock Valley.
Pricey, but it will fit perfectly. You can also purchase a DIY kit from them if you want to weld it together locally.
- Just call them, as their website doesn't list all that they carry.
Tanks Inc. has a nice DIY pump kit that you could have a shop weld into your stock tank also: http://www.tanksinc.com/index.cfm/pa...=cat/cat61.htm
Some helpful links on the topic:
http://board.moparts.org/ubbthreads/...Number=6930817
http://board.moparts.org/ubbthreads/...Number=6814508
http://www.thedetailzone.com/Tanks%2...%20Install.htm
http://www.bigblockdart.com/forum/sh...lbro#post55617
Here is a link to S&P performance where they install a 6.1 hemi into a 1966 Belvedere.
S&P used 99-up LSx corvette fuel system parts for the install. (Filter regulator, ect.) This makes it easy to source parts to perform the swap.
Another link to the same pics: http://spankysrodshop.net/index.php?...d=15&showall=1
![](http://spankysrodshop.net/images/stories/66Satellite/IMG_1146.JPG)
![](http://spankysrodshop.net/images/stories/66Satellite/IMG_1207.JPG)
![](http://i207.photobucket.com/albums/bb115/djvcuda/MOE/DSC_8673.jpg)
![](http://spankysrodshop.net/images/stories/68GTXHemi/GTX0115.jpg)
99VetteFRC, thanks for the picture and suggestion. The setup you have on your chevelle is very similar to the setup that I currently have, only I'm using a fuel cell. I was hoping to use an intank pump, looks like rock valley will be the ticket.
Topbrent, sent you a pm.
Ace, If you post pics, I promise not to forward them to moparts, thereby reducing the risk of life threats. I just haven't seen one on here yet.
I think I'm going to end up going with a f-body gas tank. I found one at a steal of a price. Even after fabrication cost to the plymouth in order to properly mount the tank, I will be way under cost of a reproduction tank with in tank fuel pump. So we will see how it goes...if it wont work then I guess I will have to end up going the reproduction with intank option. Thanks for the suggestion leon phelps.
