Smoothed Truck Intakes
#241
I am struggling with how much to shave on mine (wire harness guides are already gone). Part of me wants to shave everything/relocate ports to the rear...but then I have to do something with the ugly fuel rails and crossover. Yours looks like how the factory SHOULD have done it.
#243
It is welded. but not sanded smooth. I need to take it over to dad's house for that.
IMG_7129 by Flipper_1938, on Flickr
What did you do about the EGR hole and the purge solenoid hole? Did you weld those up too?
![](https://c1.staticflickr.com/1/315/18394673738_a81a6ed5c9_b.jpg)
#244
I haven't seen any nnbs/tbss intakes done up so I thought I'd do mine and share the progress
![Name: 20150813_131848_zpsyag1bpz7.jpg
Size: 122.3 KB](https://ls1tech.com/forums/attachments/conversions-swaps/604561d1501291911-smoothed-truck-intakes-20150813_131848_zpsyag1bpz7.jpg)
![Name: 20150813_134243_zpslzcykupe.jpg
Size: 114.1 KB](https://ls1tech.com/forums/attachments/conversions-swaps/604562d1501291911-smoothed-truck-intakes-20150813_134243_zpslzcykupe.jpg)
left some of the ribs for structure
![Name: 20150813_142129_zps0adqzrnn.jpg
Size: 93.9 KB](https://ls1tech.com/forums/attachments/conversions-swaps/604563d1501291911-smoothed-truck-intakes-20150813_142129_zps0adqzrnn.jpg)
![Name: 20150813_142523_zpsbxdylggs.jpg
Size: 115.1 KB](https://ls1tech.com/forums/attachments/conversions-swaps/604564d1501291911-smoothed-truck-intakes-20150813_142523_zpsbxdylggs.jpg)
3m panel bond
![Name: 20150813_144136_zpscwvzt0pg.jpg
Size: 106.7 KB](https://ls1tech.com/forums/attachments/conversions-swaps/604565d1501291911-smoothed-truck-intakes-20150813_144136_zpscwvzt0pg.jpg)
roughed it out and decided to remove pcv and relocate map ports
![Name: 20150814_101440_zpssel4j0pg.jpg
Size: 205.5 KB](https://ls1tech.com/forums/attachments/conversions-swaps/604566d1501291911-smoothed-truck-intakes-20150814_101440_zpssel4j0pg.jpg)
used the evap port for the map, throttle body bracket will hold it in place
![Name: 20150814_100052_zpsovmnpxsg.jpg
Size: 207.9 KB](https://ls1tech.com/forums/attachments/conversions-swaps/604567d1501291911-smoothed-truck-intakes-20150814_100052_zpsovmnpxsg.jpg)
another coat of panel bond
![Name: 20150814_110929_zps747xilwp.jpg
Size: 95.5 KB](https://ls1tech.com/forums/attachments/conversions-swaps/604568d1501291911-smoothed-truck-intakes-20150814_110929_zps747xilwp.jpg)
That's all for now until more progress.
3m panel bond
#245
![](http://i183.photobucket.com/albums/x244/95stro/20150813_131848_zpsyag1bpz7.jpg)
![](http://i183.photobucket.com/albums/x244/95stro/20150813_134243_zpslzcykupe.jpg)
![](http://i183.photobucket.com/albums/x244/95stro/20150813_142129_zps0adqzrnn.jpg)
![](http://i183.photobucket.com/albums/x244/95stro/20150813_142523_zpsbxdylggs.jpg)
3m panel bond
![](http://i183.photobucket.com/albums/x244/95stro/20150813_144136_zpscwvzt0pg.jpg)
![](http://i183.photobucket.com/albums/x244/95stro/20150814_101440_zpssel4j0pg.jpg)
![](http://i183.photobucket.com/albums/x244/95stro/20150814_100052_zpsovmnpxsg.jpg)
![](http://i183.photobucket.com/albums/x244/95stro/20150814_110929_zps747xilwp.jpg)
3m panel bond
#246
#254
Here are some videos of some of the abuse that I put it through.
Big burnout video:
Big Smokey Burnout '87 Chevy Truck 5.3 Power - YouTube
Lots of WOT pulls:
5.3 Swap '87 Chevy Truck WOT Pulls + Locker Rear - LS1 LSx C10 R10 - YouTube
Big burnout video:
Lots of WOT pulls:
What exhaust are you running??
#257
1 Post
They say that their is. I'm not sure that I'm convinced yet.
I see that their could be potential for more air flow with it's larger TB but if the air flow isn't needed for the particular engine, then their'd be no power gains.
People have made plenty of power with a 78mm TB. Guess it all depends on your engines power goals.
#258
I'm not sure this would actually be testable. Correct me if I'm wrong, but aren't gen3's cathedral port heads and gen4's rectangular port? So the two intakes wouldn't even be matched up correctly to the head if you wanted to do a back to back test.
#260
1 Post
I just realized that I've never looked at a truck intake that came with 6.2L L92 heads square port heads yet.
