AMC Eagle swap questions
I've done a little searching but didn't find a definite answer. How can I tell what vehicle this engine came from? It appears to have at least an LS1 intake not sure about the accessories.
The wiring job is quite sloppy, I'll have to address that in the future. A buddy of mine did a couple LSx swaps and notice the plug for the IAT just hanging there. He gave me one with a connector because the IAT he had didn't match my plug, but I really don't want to splice in a new plug if I don't have to.
My other Eagle that is still AMC 6 powered, for now.
Look under the water pump on the driver's side of the engine. 4.8/5.3 should be cast into the block with one circled in paint stick. That should at least narrow down your search.
Awesome car! Clean up that engine bay and keep us posted.
If you need an LS IAT, they cost like 20 bucks. GM used the same IAT for 30 years. Mine came from a 96 Camaro. For how cheap they are, it can't hurt to run one.
As for what you have, the older 5.3 pistons are dished and the 4.8s use flat tops. Some say you can see enough from the spark plug holes to ID, but I don't see how you could without having them side by side to compare.
Mine too. I just wish the execution was better. It's a little sloppy. It smokes the tires rather easily, though.
