A-body p/s hose configuration pics
I've been combing through peoples swaps and haven't found any clear pics of the p/s lines. I'm thinking about using aeroquip -6 lines and fittings to make it as clean as possible.
Anyone got a link of some photos?
Andrew
If you are using truck pump, take the fitting out of the back of the pump (1" wrench) and swap it with the one in the origional pump. then the stock A-body power steering hoses screw right in. No need to spend funds.
strg
I've got a GC box going into it at the same time. I also ordered 2 sets (for some reason) of the lee adapters that press into the box to make them back into the old style inverted flare. I guess i'll wait until the engine i in for the last time and either make up a line or try to match up an oem one that looks like it belongs there.
Yeah BC, that's what i'm thinking. That way you can make it a nice length with enough slack for engine movement, but not a huge loop like the other thick rubber press. side hose.
Thanks guys
Thanks guys
