What stall converter
Let me know what you are running & if you like it.
Thanks
Just my 2 cents..
BC
That might be a "corporate" 8.5" rear end. If so they can be plenty strong so I would not change it. I would drop and Eaton posi in it and the gears of your choice.
By the way I just bought one for my 1965 Buick Skylark. I chose the Eaton posi, 30 spline axles and 3.23 gears because of the 6L80E transmission I will be running. Probably will be going with a 3200 stall with my L92 motor.
I am about to replace my Nova's 8.2" with an built 8.5", just going to drop in a 30 spine posi, HD Axle and a good set of gear.. it should hold up for want I plan (a few days at the drag and some Auto-X).
You should be ok with the 8.5" for what you have stated your goal is.
BC
. It will depend on his right foot
