waterpump,alt,crank.....
Old Jun 24, 2012 | 07:43 PM
Doug G's Avatar
Default waterpump,alt,crank.....
Whats the cheapest route to go with the most choices ?
I will not have power steering or AC...I have a blank slate and will need it all.
help ?
Old Jun 24, 2012 | 07:53 PM
99VetteFRC's Avatar
I used truck accessories with an LS1 waterpump and swapped out the truck water pump pulley. Only to use the LS1 intake on my truck engine. works great.
Old Jun 25, 2012 | 03:20 AM
garys 68's Avatar
truck bracket, they're a dime a dozen. Just mount the alternator, route the belt under the WP instead of the "S" routing.
Old Jun 25, 2012 | 07:02 AM
cruisin'73's Avatar
Gary is probably right. Using stock truck accesories would be very easy and cheap. I have seen guys on here even hacksaw or mill the unused PS pump portion of the bracket off.
For my build I used a truck crank pulley, WP and tensioner and alt. But I used an F-body alt bracket and had a spacer plate made to give me the correct belt alignment as the truck belt system is about 3/4" further out from the front engine face. Check out my thread for more pictures.
Old Jun 25, 2012 | 07:32 AM
lebedin8654's Avatar
Good question I will be heading to the junk yard this weekend!!
Old Jun 25, 2012 | 03:11 PM
Doug G's Avatar
hhhhmmmm... I have the truck bracket but my alt. doesn't fit that good (CS130 new that was on my 406) and I like the looks of that F-body bracket.
I was looking at relocation kits and $150-$200 for a bracket ? LOL not this guy, I'll make one first
Decisions decisions.
Old Jun 25, 2012 | 03:25 PM
garys 68's Avatar
I've been running my alternator like this a few years. You could use the stock tensioner instead of the idlers and compressor.
https://ls1tech.com/forums/conversio...rive-done.html
Old Jun 25, 2012 | 07:51 PM
Doug G's Avatar
Looks good....hhhhmmmmm, more ideas
Old Jun 26, 2012 | 02:48 AM
71ANTICARB's Avatar
What intake are you planning on going with? Car intakes will have some interference issues with the truck wp. Nothing that isn't a pretty simple fix. I ended up going with the F-body accessories., pieced it together pretty cheap. But I do have ps. And the low mount alt had some territorial disputes with the steering rag joint but nothing the grinder couldn't handle.
Old Jun 26, 2012 | 04:34 AM
Doug G's Avatar
VicJr. and a carb.
